why do my ac compressor make noise?
Old 07-28-2005, 11:08 PM
P-DuBB's Avatar
Default why do my ac compressor make noise?
i recently just bought a 99 si with a blown motor.....well anyways ,i just put the new motor in started and runs good... the only problem is that when i turn the ac on it make a wierd noise, but the ac works and evreything, just make a funny whistling noise....wat could be the problem?
does anyone on HT know wats wrong with my ac....
Old 07-28-2005, 11:09 PM
P-DuBB's Avatar
Default Re: why do my ac compressor make noise? (P-Dubb)
need info ...please help
Old 07-28-2005, 11:45 PM
* B A N N E D *
Redline96LX's Avatar
check the belt for vibration. also could be the bearing, is it a whistling or a squealing kinda noise? maybe the a/c clutch is bad in the compressor. also check your fan inside the cabin.
P.S. Cool avatar
Old 07-31-2005, 02:07 AM
P-DuBB's Avatar
Default Re: why do my ac compressor make noise? (Redline96LX)
i check on that .....thanks
Old 07-31-2005, 08:14 AM
Chiovnidca's Avatar
Belt noise? Has the ac system ever been open?
Old 07-31-2005, 03:43 PM
P-DuBB's Avatar
Default Re: why do my ac compressor make noise? (Chiovnidca)
no its never been open ...
Old 07-31-2005, 04:45 PM
99exd16y8's Avatar
Your avatar is killing me.
Old 07-31-2005, 11:32 PM
P-DuBB's Avatar
Default Re: why do my ac compressor make noise? (99exd16y8)
Old 08-02-2005, 06:31 PM
Junkiii Ek's Avatar
ac pump is going out buddy...had the same prob with my black coupe...
Old 08-02-2005, 08:50 PM
P-DuBB's Avatar
Default Re: why do my ac compressor make noise? (Junkiii EJ8)
u think so ...man that sound $$$ to fix
Old 08-02-2005, 09:35 PM
The Maniac's Avatar
I've got the same problem. If you're driving and you go over 3k rpms the ac squeels like a stuck pig and everybody stares at you, it sucks.
Old 08-02-2005, 11:22 PM
H-T White Ops
Frozen E's Avatar
Compressor is on it's way out. Bad bearings in there. Probably caused by lack of oil (means you had/have a leak somewhere and whoever had the motor before you just kept topping it off with gas but no oil). Now your bearings in the compressor are shot.
Old 08-03-2005, 11:50 AM
timisyourfriend's Avatar
Default Re: (IslandSi)
I bought an AC compressor a while back ago for $50, they go for like $300 I believe... but yea, if you find one for cheap and have someone charge it up, it won't be too bad to your pocket. Just use what you got till its shot. (=
Old 08-03-2005, 03:39 PM
99exd16y8's Avatar
Default Re: (JZPerformance)
i got a compressor i will sell you from a 99 ex 50$
Old 08-04-2005, 08:23 PM
P-DuBB's Avatar
Default Re: (99exd16y8)
i dont think a ex compressor will work on mines
Old 08-06-2005, 01:05 PM
P-DuBB's Avatar
Default Re: (P-Dubb)
the noise sound like its coming from my ac fan ....but wat do u think is wrong with the fan
Old 08-06-2005, 06:01 PM
EG-SI(rII)'s Avatar
Damn that's hot. If those are your titz, marry me.
Old 08-06-2005, 06:10 PM
D15Bbigred's Avatar
Default Re: (EG-SI(rII))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-SI(rII) &raquo;</TD></TR><TR><TD CLASS="quote">Damn that's hot. If those are your titz, marry me. </TD></TR></TABLE>
umm yeah, anyway, i dunno mine does the squeeling of the stuck pig, but i heard belts, it only does it if i shift hard from 1st too 2nd, also mine does the whistling too
Old 08-06-2005, 06:39 PM
P-DuBB's Avatar
Default Re: (EG1racer)
mines come on when i hit the ac button ....then after i drive for like 10 minutes it goes away....then repeats cycle........wats the problem guys....that sound is really buggin the **** out of me
Old 08-08-2005, 10:43 AM
arr
arr's Avatar
I have a similar (if not same) problem with my pre-certified '02 Accord V6 -- i took it to honda complaining that i hear a faint gurgling noise when my AC is on, but i was told that all hondas have this problem when the A/C compressor swings into action. It was hard to believe that all hondas have this problem!! Pls. advice... is my unit bad as well?
Old 08-08-2005, 01:57 PM
Chiovnidca's Avatar
Default Re: (arr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arr &raquo;</TD></TR><TR><TD CLASS="quote">-- i took it to honda complaining that i hear a faint gurgling noise when my AC is on, but i was told that all hondas have this problem when the A/C compressor swings into action.</TD></TR></TABLE>
If it's coming from the right side of the dash when the a/c cycles, it's normal.
Old 08-08-2005, 03:23 PM
dpkelly's Avatar
Default Re: (Chiovnidca)
It could also be the bearings inside the tensioner pulley. Move the belt off both the pulley and compressor and then try spinning them by hand and see if they rotate freely. BTW, you'll have to remove the powersteering pump to do this which is quite easy and gives you the room you need. Good luck
Old 08-08-2005, 04:24 PM
Bcuz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P-Dubb &raquo;</TD></TR><TR><TD CLASS="quote">i recently just bought a 99 si with a blown motor.....well anyways ,i just put the new motor in started and runs good... the only problem is that when i turn the ac on it make a wierd noise, but the ac works and evreything, just make a funny whistling noise....wat could be the problem?
does anyone on HT know wats wrong with my ac....</TD></TR></TABLE>
It could be low on charge or your compressor clutch is slipping. I'd lean towards the later of the two.
Old 08-08-2005, 10:36 PM
P-DuBB's Avatar
Default Re: why do my ac compressor make noise? (Bcuz)
my noise is coming from the right side vent on the dash
DeeJaayM
Honda Civic (2006 - 2015)
07-16-2018 08:16 PM
plotomatic
09-24-2016 11:10 AM
wickedmaniac
12
06-06-2014 08:18 AM
elpiar
03-22-2005 03:50 PM
PnX-R
06-08-2002 06:36 PM
Quick Reply: why do my ac compressor make noise?
