What are the torque specs of a b18c1 with a b16 head with arps?
Old 05-27-2005, 09:24 AM
B16Civic93's Avatar
Default What are the torque specs of a b18c1 with a b16 head with arps?
How many ft/lbs should i torque my head down with. its going to be a b18c1 witha cometic head gasket and arp head studs. also what is the torque sequence? sorry i've never had to replace a head before on a honda so i'm not sure what the specs are for it.
Old 05-27-2005, 09:55 AM
EJ8Joel's Avatar
Default Re: What are the torque specs of a b18c1 with a b16 head with arps? (B16Civic93)
70 ft pounds with ARP assy lube.
Old 05-27-2005, 10:02 AM
B16Civic93's Avatar
Default Re: What are the torque specs of a b18c1 with a b16 head with arps? (JDMJoel)
are you saying with arps assembly lube? and what is the torque sequence? and do i torque them 70ft lbs right off the bat or do i step it up like 30, 50, 70?
Old 05-27-2005, 11:30 AM
ITR981002's Avatar
I believe its 30, 50 then 72.
Old 05-27-2005, 11:45 AM
B16Civic93's Avatar
Default Re: What are the torque specs of a b18c1 with a b16 head with arps? (ITR981002)
and what is the torquing sequence
Old 05-27-2005, 12:59 PM
ITR981002's Avatar
I've always used this without a problem:
7 5 1 3 9
10 4 2 6 8
Somone will probably quote the Helms which I believe is slightly different, either way.
Old 02-01-2012, 03:27 PM
De sol 4 ya's Avatar
My arps called for 80 ft lbs in my b16
Old 02-01-2012, 06:22 PM
phaphon's Avatar
same with my gsr
Old 02-01-2012, 07:16 PM
93h2beg's Avatar
start torquing from the inside of the head out. all to 30 or whatever, then 50, then 70 or 80. inside out. I have had to replace so many head gaskets for friends who had "mechanic" do the head install but didn't torque it right. its not rocket science. start from the inside and cross back and forth. like ITRXXXX said. start at 1 then move to 2 then 3 then 4 and so on.
easy, not even super crucial if u do it
9 3 1 5 7
8 4 2 6 10
just make sure they all hit the same ftlb in the end. then wait a while and recheck.
Old 02-02-2012, 05:10 PM
blackeg's Avatar
9 3 1 5 7
8 4 2 6 10
yes thats the sequence right there. make sure your last step is the largest, so i recommend 25 - 50 - 80 ftlbs. moly lube on the threads where the nut goes on. i think they are best installed into the block with regular engine oil to about 10 ftlbs. i used to have a good amount of headgasket issues until i started installing them like this. havent lost one since and its been a few years now
Old 02-02-2012, 10:31 PM
DC4KiD's Avatar
Same here.
Old 02-03-2012, 08:02 AM
b20ricepower's Avatar
Yea what everyone else said basically. Its 80ftlb with moly lube or 85ftlb with 30wt motor oil. Torque from the inside of the head to the outside or any of the sequences listed above and you will be fine. Btw you can print instructions off of arp's website and helms manuals are available for download online free. That would of given you all the info you needed
Old 02-03-2012, 09:53 AM
sanman000719's Avatar
i went to 83flb myself on golden eagle head bolts
Old 02-03-2012, 09:54 AM
i also found this a while ago and it helps me out from time to time
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/faq-b-series-torque-specs-953151/
Old 02-03-2012, 12:30 PM
Root of all Evil's Avatar
I know you are using arp's but the repeated torquing to 50lbs for accuracy might make sense for you also.
These are golden eagle's instructions fwiw
1st step, torque the nuts to 25 ft. lbs.
2nd step, torque the nuts to 50 ft. lbs.
While still going in the factory torque sequence, loosen each nut one at a time ½
turn then torque back to 50 ft. lbs. Repeat this step three ( 3 ) times. This will mate
the threads and give more accurate torque reading upon final torque.
Last step, torque to 72 ft. lbs.
I blew 2 cometic hg's using arps, now on golden eagles oem hg and studs and all is well finally.
Old 02-03-2012, 04:19 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
^^^ Did you ever heat cycle the engine appropiately and retorque the ARPs? I have NEVER lost a headgasket with ARP's on my imports or domestics alike, be it my circle track engines or daily drivers. Given, it's a major PITA on a Honda, but on a SBC it's easy as pie.
Everything I have seen from "Golden Eagle" seems to be inferior quality. Personally, I wouldn't run anything they make, but to each his own. Also, that "conditioning" they want you to do to their head studs is close to the same process as setting rod bolts... Hmmmm.
Old 02-04-2012, 07:06 AM
Never heat cycled and retorqued the arp's. That step is news to me. I have very large hands and I hate timing belt work on an installed b series
roger93si
01-16-2007 10:12 AM
kholmes
04-23-2005 03:25 PM
igy
11-03-2004 05:12 PM
Quick Reply: What are the torque specs of a b18c1 with a b16 head with arps?
