Cigarette Lighter Fuse?
Old 02-06-2002, 06:25 PM
Ranger's Avatar
Default Cigarette Lighter Fuse?
The lighter quit working in my 93 Accord EX, and neither fuse block has a blown fuse, or shows a fuse protecting the lighter. Anyone know where to look?
Old 02-06-2002, 06:32 PM
bob01721's Avatar
Default Re: Cigarette Lighter Fuse? (Ranger)
There IS a fuse protecting the lighter, but I couldn't tell you where it is in an Accord. It could also be the relay. Or the cig lighter itself. Did you try swapping it with one from another car?
Old 02-06-2002, 06:33 PM
ArchAngel Sabastian's Avatar
theres a fuse in/behind the lighter itself.
Old 02-06-2002, 06:36 PM
Ranger's Avatar
Default Re: Cigarette Lighter Fuse? (bob01721)
Yea, I switched lighters, tried a phone charger, and then checked for power - there ain't none there. Got to be some protection somewhere...
Old 02-06-2002, 06:38 PM
Ranger's Avatar
Default Re: Cigarette Lighter Fuse? (Sabastian)
Sabastian, how does one attack it?
i have a 5th gen so i dunno if this goes for you too but on the back of my cig lighter there is a (ground?) wire and its VERY fragile like connected it will brake off VERY easily and you wouldnt notice. try that maybe
Old 02-06-2002, 06:42 PM
Ranger's Avatar
I will try that after work tomorrow - will post results.
Thanks, guys.
Old 02-06-2002, 06:47 PM
bob01721's Avatar
That's a good point about the wiring behind the lighter. There's also a relay that feeds the lighter. On mine (Acura) it's right above the under-dash fuse fuse box. Don't know if yours is in the same place, but there IS a relay in a cig lighter circuit.
Old 02-07-2002, 02:08 PM
Banned
Bklyn TSi's Avatar
omg, I'm glad somebody noticed it! mines broke and for a while I went crazy looking for the solution! Now the ground piece is hung by a metalic wire...
Old 02-09-2002, 06:58 PM
Ranger's Avatar
Default Re: Cigarette Lighter Fuse? (Stony TSi)
No loose wires- I will try to get ahold of a wiring diagram.
Old 02-10-2002, 10:28 AM
weekendracer's Avatar
On my 92, the cig lighter is on the fuse marked 'radio/motor antenna' in the kick panel
Old 02-10-2002, 07:14 PM
Ranger's Avatar
Default Re: Cigarette Lighter Fuse? (weekendracer)
Well, both those accessories are working...
Old 02-11-2002, 12:05 PM
bob01721's Avatar
If the stereo and the antenna motor are getting their juice, then the cig relay is getting all its inputs. If its contacts are corroded, it won't be able to get voltage to the other side of the relay. No voltage to the cig lighter.
Do you have a voltmeter or a 12V test light?
MSchu
10-27-2008 09:55 AM
fiveaces
09-03-2008 02:21 PM
Sic_DA_Nine
01-08-2007 09:54 AM
Sic_DA_Nine
Audio / Security / Video
01-07-2007 11:04 AM
cd5_2NR
07-01-2004 01:38 PM
Quick Reply: Cigarette Lighter Fuse?
