| Welcome to Honda-Tech! | ||
#1 |
i have a gsr head off the motor already...is there a way i myself can check for bent valves?
#2 |
pour gasoline into the combustion chamber and see if it leaks out intake/exhaust ports
#3 |
Mad Scientist
or brake cleaner.
i usually put it in the ports and see if it leaks into the comb. chamber.
-2290 DC2= e85 powered -DB2 EFI 101 -- PGMFI.ORG-- crome-- have a question about ducati's? ducati factory trained |
#4 | |
#5 |
| Garage is empty, add now |
I use paint thinner as it is safer than gasoline but works the same. Do it in a ventilated area.
#6 |
Out of curiousity how's putting gasoline in the combustion chamber, less safe?
#7 |
ok i did that...now in 3 intake valves there is a slow slow leak...like it will drip maybe twice a minute..does it need new valves? or is there an alternative fix?
#8 |
There is a possibility it could be carbon buildup on the seat or where the valve contacts the seat. Maybe you should find out if the valves are bent or if they just aren't sealing.
obd2a p72 ecu, gsr intake manifold. http://hondamarketplace.com/showthre...5#post46281085 |
#9 |
I'm curious, is this how machine shops check for bent valves? Or is the leaking method only checking for worn valve seals?
#10 |
Mad Scientist
shops vacuum test.
If you have a leak i would take the valve out and check for straightness, if its just carbon and such you could get away by just facing the valves/regrinding the seat; if there is no mushrooming
#11 | |
#12 | |
| Tags |
| 2000, bend, bent, car, check, checking, civic, crv, fix, gasoline, good, gsr, head, honda, leaking, test, valve, valves |
