Where is the grommet(firewall) hole in a 2002 civic si?
im installing my brothers amp for him and i cant seem to find the grommet hole (the hole in the firewall which has a plastic plug in it) so that i can run the power cord through it...does the 02 si not have a pre-made hole in the firewall for wiring? i know my 93 accord does but im not sure if the si does...
Re: (1995Ex_Sedan)
i meant like relative to the inside of the car...like on my accord there was a grommet plug behind the carpet on the passenger side of the car
Re: (10th_anv_cb7)
not all cars have them, sometimes you have to go thorugh an exisiting engine harness gromment, or drill a new hole and grommet it yourself with the one that came in your amp install kit.
Re: (doublethink)
i got stuck doing an Si.. there's no room worth **** on that firewall. Tapping your own hole is pretty much out of the question. I was forced to go thru the factory gromet on the pass side about a foot and a half from the fender. Used a razor blade to make a small cut, and had to screw with a wire puller for about 35 minutes to find where it came out in the car. Have to admit doing those cars is not real fun lol
Old Fart
Re: (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 »</TD></TR><TR><TD CLASS="quote">i got stuck doing an Si.. there's no room worth **** on that firewall. Tapping your own hole is pretty much out of the question. I was forced to go thru the factory gromet on the pass side about a foot and a half from the fender. Used a razor blade to make a small cut, and had to screw with a wire puller for about 35 minutes to find where it came out in the car. Have to admit doing those cars is not real fun lol</TD></TR></TABLE> Ditto.......... the older Honda/Acuras had all sorts and sizes of unused holes with "dummy" grommets in them, not so with new cars, [no more then needed] even if it only costs Honda $0.02 for a dummy grommet in a civic after 1 million cars x 3 or 4 grommets per car, I would love to get the 6 to 8 grand it saves them. Here is a trick I use to cut holes in grommets to keep them waterproof, I have about 10 old staged ant., [ 3,4 and 5 part, the slide into themselfs to make the ant. shorter or longer] I take them apart and end up with diff. diameter "tubes", sharpen the outside edge at one end, and you have a "grommet hole saw" use one that is a little smaller in gage then the wire to cut a clean round hole in grommet, that is damn near airtight when wire is in. 94
yesirthepoptart
03-19-2010 04:52 AM
