Amp Wiring Issues
Old Dec 8, 2008 | 12:57 PM
rexzilla25's Avatar
Default Amp Wiring Issues
I have a '96 Accord and I just started looking at places to run my amp power wire, I can't really find any existing holes in the firewall and I tried looking for pictures or something. I would prefer to not drill a hole but rather use an existing grommet. If anyone could help, it would be greatly appreciated.
Thanks
Old Dec 8, 2008 | 06:22 PM
hondamark35's Avatar
the short answer... you haven't looked hard enough.
think about what else has to go through the firewall and follow alongside that. you should be able to go through the fender as well.. if you pull the passenger front wheel and then the inner fender lining you should have easy access to a wire harness going into the "kick panel" area. route from the battery into the fender and then follow the wires. tie strap as needed.
Old Dec 9, 2008 | 08:01 AM
lee0149's Avatar
dont you just hate when people dont tell you and ask you to do the research. when this site is apart of your research. LOL will follow the engine harness it goes under the battery you can stick the wires threw their with the harness. also on the drivers side there should be a hole there too. hope this helps.
Old Dec 9, 2008 | 08:56 AM
NVturbo's Avatar
O.G. triple O.G.
hondamark35, removing the fender is not necessary for an amp install. Like lee0149 said, there is a rubber plug on the lower portion of the firewall (passenger side). Just make sure you properly zip tie the wire so it wont get caught up and cause a fire.
Old Dec 10, 2008 | 05:58 PM
rexzilla25's Avatar
thanks guys, check out my other post, i think i may have found another way...tell me what u think there(included pictures)
Old Dec 10, 2008 | 06:02 PM
rexzilla25's Avatar
https://honda-tech.com/forums/showth...358&highlight=
xxbvanxx
May 30, 2010 06:25 PM
JDMoneDC5
Jul 31, 2009 09:17 PM
JHJams
Oct 29, 2008 10:07 PM
bm3r
Audio / Security / Video
Jun 26, 2004 08:00 PM
TrikMeister408
Nov 27, 2002 06:27 PM
