Could a bad alternator cause bogging or poor/insufficient spark?
Old 04-04-2005, 08:28 PM
Keith's Avatar
Default Could a bad alternator cause bogging or poor/insufficient spark?
Question, could a bad alternator cause a poor/insufficient spark under half to full acceleration which results in bogging?
Keith
Old 04-05-2005, 05:15 AM
Keith's Avatar
Default Re: Could a bad alternator cause bogging or poor/insufficient spark? (Keith)
bump
Old 04-05-2005, 05:34 AM
Old_Nocturnal's Avatar
I went thru a few alternators when my downpipe was cracked, and my car would run fine all the way down to between 10 and 9 volts on the turbo timer. All of the dash lights and headlights would go out before the car would quit running.
Old 04-05-2005, 05:41 AM
AndyD's Avatar
Hey Keith,
I had the same exact question for my 240SX. My battery light would light up a little too. I changed the alternator and it DID NOT fix the problem. My bogging is caused by another problem. If I get on the gas more than 25% of full throttle, the car bogs...bad.
On my Prelude, I accidently unplugged my alternator plug when i was adjusting my accessory belts. The car ran off the battery for 2 days. When the battery finally started to die, the car bogged pretty bad. But that only happened for less than a minute until the battery died. Before the battery died, the car ran fine.
At idle, if you try to rev up the car, does it bog then too?? I am trying to figure out my problem on my 240SX still. I think a few of the valves are bad because I've tried changing MANY different parts.
Anyway, if you need an alternator, let me know. I have one for sale. It's from a 4th Gen.
Old 04-05-2005, 09:41 AM
Keith's Avatar
Default Re: Could a bad alternator cause bogging or poor/insufficient spark? (AndyD)
Thanks Andy, I already bought another alternator. I'm going to install it tonight.
Keith
Old 04-05-2005, 10:08 AM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Andy, I already bought another alternator. I'm going to install it tonight.
Keith</TD></TR></TABLE>
let us know if it changes anything, but i have had a bad alternator cause bogging , but the battery was practically dead too,
Old 04-05-2005, 05:46 PM
Keith's Avatar
Default Re: Could a bad alternator cause bogging or poor/insufficient spark? (prelittlelude)
Replaced the alternator... started her up and there was a bit of bogging at first... but I think it was the left over fuel (flooded) from the WOT test I was doing before on the bad alternator. So far so good
Keith
Old 04-05-2005, 09:43 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">let us know if it changes anything, but i have had a bad alternator cause bogging , but the battery was practically dead too,</TD></TR></TABLE>
me two, but it was a bad battery
JasonYo
09-01-2010 10:42 PM
89edcivic
09-26-2009 02:38 PM
rasta420
10-02-2006 04:46 PM
Martaigne
07-14-2002 04:19 PM
Quick Reply: Could a bad alternator cause bogging or poor/insufficient spark?
