No heat in my accord!!!
Old 01-25-2005, 01:17 PM
CHARD23's Avatar
Default No heat in my accord!!!
I changed the thermostat... And Im still getting no heat... The engine is not overheating ... WHat can I do??
Old 01-25-2005, 01:30 PM
JimBlake's Avatar
Default Re: No heat in my accord!!! (CHARD23)
You can tell us what year/version of Accord... They're not ALL exactly the same.
Check either air bubbles in your cooling system, or maybe a cable disconnected from the control **** to the actual valve.
Old 01-25-2005, 01:42 PM
Atheist's Avatar
If the heater core and fan blower are recieving power, replace the heater core.
Old 01-25-2005, 01:51 PM
CHARD23's Avatar
99 ex..4 cylinder...
Where's the heater core?
Old 01-25-2005, 03:00 PM
momstaxi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHARD23 &raquo;</TD></TR><TR><TD CLASS="quote">99 ex..4 cylinder...
Where's the heater core?</TD></TR></TABLE>
underneath the dashboard in the center against the firewall.
Old 01-25-2005, 04:09 PM
CHARD23's Avatar
Default Re: No heat in my accord!!! (momstaxi)
WHat about that sensor on the thermostat...Could that cause the lack of heat...?
Old 01-25-2005, 05:09 PM
21tgs's Avatar
That sensor sends the signal to your temperature gauge in your dashboard.
Old 01-25-2005, 05:28 PM
SlammedAccord96's Avatar
Default Re: No heat in my accord!!! (21tgs)
Sounds like the heater core.
Old 01-26-2005, 03:49 AM
JimBlake's Avatar
Default Re: No heat in my accord!!! (SpeedFreak03)
First check the simple stuff. My '98 temperature **** broke at the little collar that pressed onto the shaft. You turn the **** but it doesn't turn the shaft. Use a little JBWeld, or else the **** is pretty cheap.
That **** turns an electrical control. There's a servo somewhere under the dash, with a cable that moves the actual heater valve. Check whether it's moving. Follow the heater hoses from the engine, one has the valve on it before going thru the firewall. It's close to the firewall, mid-height, sorta forward from the glovebox. That's got a lever that's worked by a cable. Turn the car on first, then have someone turn the heater control back & forth, while you watch for that thing to move. If that's OK, THEN you can worry about the heater core.
And like I said, check for air in the cooling system...
Old 01-26-2005, 04:44 AM
Turbowa's Avatar
Default Re: No heat in my accord!!! (JimBlake)
I will agree with JimBlake on this one. You more then likely have an air pocket stuck in the system some were.
Old 01-26-2005, 05:05 AM
CHARD23's Avatar
Default Re: No heat in my accord!!! (Turbowa)
Im goning to check that stuff..... Thanks Guys! Thanks Jim!
Old 01-26-2005, 02:47 PM
BaGGed HoNDa's Avatar
there is a little lever under the passenger side of the dash, its right there in the open. pull that back as far as you can.. you should have heat.
Old 02-01-2005, 12:24 PM
bmwe4601's Avatar
email me if you still have that problem. Kevinkim02134@yahoo.com
Old 02-03-2005, 07:46 AM
CHARD23's Avatar
Default Re: No heat in my accord!!! (bmwe4601)
I pulled the lever..I got heat now..Must have been stuck! THANKS GUYS!!!
Old 11-11-2017, 05:21 PM
dalegribble's Avatar
Hi guys,
I'm having the same problem with a 1995 Accord my friend has loaned me.
He pulled the post with the wire in the engine compartment to the right and back, but it only goes as far as 90 degrees (perpendicular with the right-front wheel). Should it go back further? After he adjusted it, the air has gone from cold to barely lukewarm.
Two posters mentioned a lever under the dash. Is this one inside the cabin, or is it the same lever I'm referring to?
Thanks!
jpdooley
01-10-2016 03:11 PM
Accccord
07-19-2011 11:12 PM
jayfrmsd
05-12-2011 03:43 AM
E30Drew
08-11-2007 08:15 PM
Myroslav
05-09-2005 02:38 PM
Quick Reply: No heat in my accord!!!
