Honda Fit/Jazz wiring Diagram
Old 01-06-2005, 09:41 PM
quacka's Avatar
Default Honda Fit/Jazz Finding Power Lock Help
I got part of this diagram but need to find the wire for the power of the fuel pump to install alarm/immobilizer. Anyone knows where i can find this? The negative door trigger switch and handbrake switch cable location would also be useful.
Thanks
Modified by quacka at 7:23 PM 1/8/2005
Modified by quacka at 7:35 PM 1/8/2005
Old 01-08-2005, 12:26 AM
quacka's Avatar
Default Re: Honda Fit/Jazz wiring Diagram (quacka)
Ok I found teh fuel pump but the remote start refuse to work. It seems like it doesn't want to pump the fuel without teh key in. Maybe it has an immobilizer. Anyone know how to bypass this?
I need urgent help finding the Power unlock and Power lock. Spent two days going through all the cables with a test light. Nothing unlocks or lock the door. Please help
Old 01-08-2005, 08:04 AM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quacka &raquo;</TD></TR><TR><TD CLASS="quote">Ok I found teh fuel pump but the remote start refuse to work. It seems like it doesn't want to pump the fuel without teh key in. Maybe it has an immobilizer. Anyone know how to bypass this?
I need urgent help finding the Power unlock and Power lock. Spent two days going through all the cables with a test light. Nothing unlocks or lock the door. Please help </TD></TR></TABLE>Link http://www.bulldogsecurity.com 94
Old 01-08-2005, 03:29 PM
quacka's Avatar
Tried this site. Doesn't tell me where they are.
Someone told me white/blue white green but i cant find this cable anywhere that triggers the door
Old 01-08-2005, 07:57 PM
fcm
Old Fart
fcm's Avatar
Default Re: (quacka)
In the 2001-2004 Honda Civic they are white/blue lock and white/green unlock and they are neg. (-) trip, about a 250mA 1/4 sec. pulse, most remote starts and alarms will have at least that, and they can be found in a gray plug above the drivers kickpanel.
If the remote starts works if you put the key in the ign., [without turning it on] but will not work if the key is not in the ign. then you have a transponder key immobilizer, it turns off the injectors, if the key is not in the ign., you will need to get a bypass mod. what is the model and year of your car 94
katiejoy
07-24-2014 11:33 AM
littlecrxVTEC
12-26-2007 02:54 PM
streetsold6teeny8
11
08-06-2006 07:24 PM
yellow blur
06-15-2002 12:54 PM
Quick Reply: Honda Fit/Jazz wiring Diagram
