Old 12-29-2004, 04:06 PM   #1
EK k kay
EK k kay's Avatar
Default Brown sludge in coolant.
Some kind of thick slimy brown sludge is getting into my coolant and building up very slowly in my overflow tank. With the radiator cap off you can see some of it floating around in the coolant. I noticed this a week ago and I drained it and flushed it with the prestone radiator flush. Now, a few days later it's coming back very slowly again. Is it oil? Or something else? 3 weeks ago I did a mini-me vtec head swap. My motor runs fine with no cels. The oil in the dipstick and under the oil cap both look very clean.
EK k kay is offline   Reply With Quote
Old 12-29-2004, 04:10 PM   #2
toadolson
toadolson's Avatar
Default Re: Brown sludge in coolant. (chowmien)
Rust. Need to do a professional flush and add a rust inhibitor when they fill it up again. Most anti-freezes have it in them already but it's around $3.50 for the powder stuff you just add to the fluid.
I'm a dumb-a**. Work if i read the whole thing.
Modified by toadolson at 8:39 PM 12/29/2004
94 Civic DX Coupe
Engine: 1.5L, OBX Header, Cust Exhaust, Cust Intake, GSR Radiator, ES Motor Inserts
Inside: B&M SS, Skunk2 Knob, 3 Point Harness
Underneath: GC Coils 450 front/ 550 rear, Koni Yellows, Comptech Tie/Sway Bar, SRR LCA's, GSR/EX Rear Discs, Axxis Ultimates Pads
Shoes: Summer-Rota Slip's Bronze 16x7, Azenis 215/45/16, Winter-BMW BBS mesh 14x6, Futura 195/60/14
30% Integra, 70% Civic, 100% HONDA
My little autox monster!!!
toadolson is offline   Reply With Quote
Old 12-29-2004, 04:57 PM   #3
4DRmafia
4DRmafia's Avatar
head gasket?
"Gotta beat the **** out of everything to keep it lubricated"
4DRmafia is offline   Reply With Quote
Old 12-29-2004, 05:03 PM   #4
AzntaggeR
TSPeed Factory
1994 Honda Del Sol
AzntaggeR's Avatar
Send a message via AIM to AzntaggeR
Default Re: (SkipMic2006)
sounds like oil is possibly getting into the coolant. did you change the head gasket when you did a mini-me?
Speed Factory
94' del Sol B18C1-T (sold) | 01' IS300 (daily)
02' ZX-6R (sold) | 03' ZX-6R (sold) | 04' GSX-R600 (daily) | 05' GSX-R600 (stunt)
AzntaggeR is offline   Reply With Quote
Old 12-29-2004, 05:45 PM   #5
Evs-One
Gearing Owns Me
Evs-One's Avatar
Send a message via ICQ to Evs-One Send a message via AIM to Evs-One
Default Re: (AzntaggeR)
headgasket, I got 5 on it
I've done hg's on cars where the entire overflow looked like a milkshake, and so did ALL of the hoses and the radiator
Evs-One is offline   Reply With Quote
Old 12-29-2004, 05:48 PM   #6
Dr. D-Series
Dr. D-Series's Avatar
Headgasket.
Signature.
Eagle/Vitara Z6 436 whp 340 tq 10.452 @132.3, 1.625 60 ft. - Current. Xenocron Tuned.
Eagle/Vitara Y7 279 whp 210 tq 11.200 @124.5, 1.68 60 ft.
D15 Block / Y7 202 whp 160 tq 12.1 @112 , 1.70 60 ft.
Dr. D-Series is offline   Reply With Quote
Old 12-29-2004, 07:52 PM   #7
EK k kay
EK k kay's Avatar
Default Re: (Dr. D-Series)
Yeah I put a brand new oem y8 headgasket in there when I did the mini-me. Is it going to hurt if I don't change the headgasket right away?
Old 12-29-2004, 08:38 PM   #8
Evs-One
Gearing Owns Me
Evs-One's Avatar
Default Re: (chowmien)
well, depends on if you're overheating or not, and whether or not you're getting coolant in the oil.
If coolant is getting in the oil, you run the risk of damaging bearings.
Also, letting that sludge go throughout your cooling system, is bound to clog up and ruin hoses.
Old 12-29-2004, 08:41 PM   #9
EK k kay
EK k kay's Avatar
Default Re: (Evs-One)
Rats. I'm not overheating at all. I'd hate to take apart the motor again, but I guess it's gonna have to be done.
But why would the headgasket go 3 weeks after it was put in?
Old 12-29-2004, 08:47 PM   #10
Evs-One
Gearing Owns Me
Evs-One's Avatar
did you put it on upside down by chance? Were the mating surfaces clean enough to eat on? Proper torque sequence/correct head bolts? etc etc
Old 12-29-2004, 08:51 PM   #11
EK k kay
EK k kay's Avatar
I had a mechanic do it for me, he is an ex-honda dealership mechanic. He better not have put it upside down. Yes both surfaces were cleaned before putting together the motor. He tightened the headbolts from the middle on to the outside then torqued them afterwards to somewhere around 50ft/lb
Old 12-31-2004, 09:24 PM   #12
spoonef
spoonef's Avatar
Send a message via AIM to spoonef
bump for you
spoonef is offline   Reply With Quote
Old 12-31-2004, 09:54 PM   #13
green-
green-'s Avatar
Send a message via AIM to green-
Default Re: (spoonef)
Are you shooting out lots of white smoke?
Want to drive F1 cars?
http://www.honda-tech.com/showthread.php?t=2589870
green- is offline   Reply With Quote
Old 12-31-2004, 10:40 PM   #14
rippineg
rippineg's Avatar
Send a message via AIM to rippineg
most likely its a head gasket check teh oil if it looks like chocolate milk in the crankcase then it prob is
rippineg is offline   Reply With Quote
Old 12-31-2004, 10:41 PM   #15
Archidictus
Unceasing Measure
1998 Oldsmobile Intrigue
Archidictus's Avatar
Send a message via AIM to Archidictus
Default Re: (rippineg)
It's actually because you touch yourself at night.
But now the summer's dreams are bent like grain against the scythe, and memories of blissful days, they fall like leaves.
Archidictus is offline   Reply With Quote
Old 12-31-2004, 11:49 PM   #16
Eg and Me
Eg and Me's Avatar
Send a message via AIM to Eg and Me
Default Re: (Archidictus)
from someone who has blown headgaskets in a mr2, supra, bmw, and now my civic last night it's a blown head gasket...rust doesn't just "pop up"
^^^ maybe that's why i blow all of mine! haha
[B]I love Jesus[/B]
Eg and Me is offline   Reply With Quote
Old 01-01-2005, 12:27 AM   #17
EK k kay
EK k kay's Avatar
Default Re: (green00EX)
Nope not at all. I'll try and get the headgasket replaced then. Hopefully that's all the problem is.
1994, 2005, brown, cap, civic, gasket, head, honda, mesh, mini, overflow, overheating, radiator, sludge, supra
