Just installed Delta 272 Cam
Old 12-23-2004, 01:04 PM
  #26
mar778c's Avatar
Default Re: Just installed Delta 272 Cam (89SiPimpin)
You need to get a adjustable cam gear for the idle then follow fastcrxsi90's directions.
Old 12-23-2004, 06:48 PM
  #27
90LSpimpin's Avatar
Default Re: Just installed Delta 272 Cam (mar778c)
Yea thats what i figured. The problem I'm havin is that I cant keep the car running for me to even adjust the idle. Should it work the same with the car off? Cus i've backed the screw off all the way and tightened it all the way and tightening makes it not want to stay on after startin it, and loosening makes it struggle a bit b4 it dies. The only way to keep it idling was for me to make the throttle cable keep it open some.
And about the cam gear, because its a stock regrind, should it not be off a tooth because the keyway is located in the stock position?
Old 12-23-2004, 07:50 PM
  #28
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote">Yea thats what i figured. The problem I'm havin is that I cant keep the car running for me to even adjust the idle. Should it work the same with the car off? Cus i've backed the screw off all the way and tightened it all the way and tightening makes it not want to stay on after startin it, and loosening makes it struggle a bit b4 it dies. The only way to keep it idling was for me to make the throttle cable keep it open some.
And about the cam gear, because its a stock regrind, should it not be off a tooth because the keyway is located in the stock position?</TD></TR></TABLE>
No cam should be off a tooth, even if you bought a brand new cam. Are you following the idle instructions, if I remember correctly I think you need to unplug the iacv, its been a long night so I could be wrong.
Old 12-23-2004, 11:58 PM
  #29
90LSpimpin's Avatar
Default Re: Just installed Delta 272 Cam (90blackcrx)
Yea i did that. I hadnt done it the first time when i tried to adjust everything. But again it wouldnt matter because i cant keep the car on to adjust the idle.
Old 12-24-2004, 05:12 AM
  #30
Runnerdown's Avatar
I bet its off a tooth.. I put my si together off one and it would not idle. The car is bone stock, the marks are shitty on d-series.
Old 12-24-2004, 08:41 AM
  #31
90LSpimpin's Avatar
Default Re: Just installed Delta 272 Cam (Runnerdown)
Also, it runs really rich at idle and upon startup. It did this before i adjusted it anything. Theres a good amount of white smoke, which also may just be the heat as well, but u can smell that its rich from inside the car and behind it. My o2 sensor is currently not functioning properly and is disconnected, would this keep me at full rich? And i do have a cel for the o2.
Old 12-24-2004, 08:45 AM
  #32
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote">Also, it runs really rich at idle and upon startup. It did this before i adjusted it anything. Theres a good amount of white smoke, which also may just be the heat as well, but u can smell that its rich from inside the car and behind it. My o2 sensor is currently not functioning properly and is disconnected, would this keep me at full rich? And i do have a cel for the o2.</TD></TR></TABLE>
Yes a faulty 02 sensor will cause that but you said white smoke right, running rich usually means black smoke.
Old 12-24-2004, 03:33 PM
  #33
90LSpimpin's Avatar
Yea smoke's white and that carbon/condensation buildup that stains my driveway is greater now, i think. But its def running rich, you can smell it and i'm gettin about 20 miles per gallon beating on it from my usual 26 beating on it.
Old 12-24-2004, 05:04 PM
  #34
johnzm's Avatar
hey man, check your ignition timing, even at 1100 it should be *close* to the marks. a tooth off is alot of timing on the ignition. even if the idle is flucuating, it should be fluctuating *around* the timing marks. if not its off.
also, the cam timing needs to be set like stock. if it runs crappy there, try moving it a tooth foward and backward until u get a cam gear. i woudlnt run more than +/- 1 tooth tho cause thats alot of timing your messing with on that one tooth
Old 12-24-2004, 07:50 PM
  #35
90LSpimpin's Avatar
Default Re: Just installed Delta 272 Cam (johnzm)
Yea, ignition timin is close, just a little bit advanced. I should be getting a cam gear and y8 manifold in the next few days so I'll just bear with it till then. Hopefully the increased air flow will help.
Old 12-24-2004, 07:59 PM
  #36
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight &raquo;</TD></TR><TR><TD CLASS="quote">Its not a problem, you just have to keep clutch pressed down so the gearbox stops rotating.
1st then reverse. Works every time, and I never get any grindage. I make a habit of it because then I dont look like a tool when I start my car at school.
Old 12-25-2004, 11:50 AM
  #37
90LSpimpin's Avatar
Default Re: Just installed Delta 272 Cam (31flavorscivic)
Got me a Digicam for XMAS today! I'll have pics/ videos up when i get a chance and figure out how to use it.
Old 05-04-2006, 06:20 PM
  #38
I want a CRX tattoed on my butt
PINKS's Avatar
Default Re: Just installed Delta 272 Cam (90LSpimpin)
Old 05-04-2006, 07:43 PM
  #39
88crx-si's Avatar
back from the dead
Old 06-04-2006, 06:21 PM
  #40
* B A N N E D *
cbmprelude's Avatar
Default Re: (88crx-si)
what ever happened with the 272, I was thinking of getting one too?
90LSpimpin
12-22-2004 12:15 AM
90LSpimpin
12-22-2004 12:14 AM
ringgold
08-14-2001 03:58 AM
Quick Reply: Just installed Delta 272 Cam
