Doing a Great motor swap and build need help??????????
I am building my summer racer and I just picked what setup I am going with a spark racing street block and a head from them also.This is all going into a 94 auto hatch I need to know what I missed thanks guys. dont hold back on the comments
Street Stage 2 block from spark racing
P&P head from spark racing
Type R cams
Head gasket
Header
Ls wiring harness
Ls transmission--got it cheap
Type R valve cover from modacar red
Short Shifter
clutch pedal
shift linkage from GSR
Motor Mounts
Alternator
Edelbrock Manifold
Ls throttle body
All MSD ignition
p28 chipped
Anything I missed Please Let me know Thanks!!!!!!
Type R cams
Head gasket
Header
Ls wiring harness
Short Shifter
clutch pedal
Motor Mounts
Alternator
Edelbrock Manifold
Ls throttle body
All MSD ignition
p28 chipped
Re: Doing a Great motor swap and build need help?????????? (egcoupe)
Its gonna work just fine Its just for fun and street I am not trying to Win NOPI or anything
Re: Doing a Great motor swap and build need help?????????? (4doorhybrid)
That clutch pedal really adds to the car's pizzazz... summer racer or fun and strip car? Conflict of interest maybe...
I'd recommend altezzas, they make it go faster!
Re: Doing a Great motor swap and build need help?????????? (jlsmi2)
Do a search on Spark Racing, Ive seen a few people post here with some problems on the motors they did for them...
Just my 2 cents.
Just my 2 cents.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlsmi2 »</TD></TR><TR><TD CLASS="quote">That clutch pedal really adds to the car's pizzazz... summer racer or fun and strip car? Conflict of interest maybe...
I'd recommend altezzas, they make it go faster!</TD></TR></TABLE>
Hey moron: he's obviously doing an auto-to-manual conversion. Thanks for bringing the national average on the SAT down, though . Idiot.
Honestly, to the original poster, I would suggest a GSR or B16 transmission simply because the LS gears will start to feel a little long when you want to smash on it. The VTEC transmissions make better use of the torque you'll have available and, thus, are more fun to drive.
Also, if you're going to have the block open, you might as well put higher compression or at least forged internals in the block. Staying all motor without high compression is foolish and if you decided to boost in the future, you'd be kicking yourself if you had a point in the beginning when you could've put forged slugs and rods in there and didn't.
Other than those points, you have a great concept and seem well prepared. Good luck.
Re: Doing a Great motor swap and build need help?????????? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote"> The VTEC transmissions make better use of the torque you'll have available</TD></TR></TABLE>
True, get the si tranny dude, "all I want for christmas is TORQUE TORQUE TORQUE" Good luck w/ the build too man.
Hey genious! Obviously you read the first thread also! He writes " This is all going into a 94 auto hatch ," but I guess it wouldn't be TOO obvious that he would need a CLUTCH PEDAL to do an auto to manual conversion. Seems like a given.
What was your SAT score brainiac? I bet you have a great college degree in there too, Harvard's looking for people just like you
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlsmi2 »</TD></TR><TR><TD CLASS="quote">Hey genious! Obviously you read the first thread also! He writes " This is all going into a 94 auto hatch ," but I guess it wouldn't be TOO obvious that he would need a CLUTCH PEDAL to do an auto to manual conversion. Seems like a given.</TD></TR></TABLE>
What? Is that an arguement against your stupidity or defending your mistake? I can't tell because it's such a clusterfuck of punctuation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">What was your SAT score brainiac? I bet you have a great college degree in there too, Harvard's looking for people just like you </TD></TR></TABLE>
Higher than yours and yes, I will soon. And **** Harvard.
Welll the block already comes with 11:1 pistons its already built from spark racing and so is the head so Not to much to worry but I thank you for all the info and help and all the positive feedback.
slodel
12-11-2004 10:14 PM
acydphryck
06-28-2004 03:18 PM
