car blowing out white/blue smoke
Old 12-07-2004, 03:26 PM
voofee's Avatar
Default car blowing out white/blue smoke
went for a cruise last week with a friend. he said my car was blowing out a cloud of bluish smoke a few seconds after taking off from the traffic light ( he was behind me, I am guessing a few seconds mean vtec engagement in my car ).
What could be the problem? is the oil too thin?
Old 12-07-2004, 03:29 PM
Haleiwa-Brando's Avatar
Default Re: car blowing out white/blue smoke (voofee)
I will pray for you, my Son. Your future looks troubled.
Old 12-07-2004, 03:31 PM
Chris F's Avatar
Default Re: car blowing out white/blue smoke (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">I will pray for you, my Son. Your future looks troubled.</TD></TR></TABLE>
Blue == Oil
Grey/black == Fuel (Rich) and normal.
White == Steam. Either it's cold out, or you're getting antifreeze into your combustion chamber.
Don't let Brandon pray for your engine, he sucks at getting what he wants.
Old 12-07-2004, 04:51 PM
voofee's Avatar
Default Re: car blowing out white/blue smoke (ccfries)
so burning oil is consider normal? as i read that many owners have oil burning issues.
Old 12-07-2004, 04:54 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voofee &raquo;</TD></TR><TR><TD CLASS="quote">so burning oil is consider normal? as i read that many owners have oil burning issues.</TD></TR></TABLE>
Yeah, mostly normal. I wouldn't worry too much about it, but keep track of how fast you're burning it.
Is your friend sure it was blue?
You could take a peek at the spark plugs, see if any of them are fouled with oil. And/or run a compression or leakdown test.
Old 12-07-2004, 05:31 PM
Don't judge or question
Spids5's Avatar
Burning oil is one thing but when your blowing out blue smoke it means the oil is making it past the piston rings into the combustion camber and out the exhaust. It could be that the pcv valve is bad. The oil would then make it pass it and into the intake manifold instead then into the combustion camber.
Old 12-07-2004, 07:40 PM
voofee's Avatar
Default Re: car blowing out white/blue smoke (spids5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spids5 &raquo;</TD></TR><TR><TD CLASS="quote">
Burning oil is one thing but when your blowing out blue smoke it means the oil is making it past the piston rings into the combustion camber and out the exhaust. It could be that the pcv valve is bad. The oil would then make it pass it and into the intake manifold instead then into the combustion camber.</TD></TR></TABLE>
thanks, I will check my pcv valve as I never check it since I got the car
Old 12-09-2004, 06:52 AM
iperez's Avatar
Check your compression .. If you can rule out the possibility of engine damage or coolant leaking (bad head gasket) into the chambers, intall a catch can. I have 250psi on all my cylinders with JUN3 cams and I rev to 9100. I used to get A LOT of smoke up on the high revs (no smoke on daily driving). I replaced my PCV for good measure as it didn't seem to be bad and installed a catch can.. smoke went from a huge cloud to a very small puff when I change gears at high revs..
I guess we've come to accept oil burn as a normal thing on modified ITRs .. Specially if you have head work, cams, or high compression/RPMs ..
Old 12-10-2004, 10:22 AM
b16racer23's Avatar
Default Re: (iperez)
whats a catch can?
Old 12-10-2004, 08:19 PM
Spids5's Avatar
Default Re: (b16racer23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16racer23 &raquo;</TD></TR><TR><TD CLASS="quote">whats a catch can?</TD></TR></TABLE>
A can that catches stuff.
Old 12-11-2004, 04:22 AM
voofee's Avatar
Default Re: (spids5)
lol, b16racer see link below
http://www.c-speedracing.com/h...n.php
Old 12-11-2004, 07:41 AM
boostjunkie757's Avatar
mine smokes like a banshee...
but then again, when the wastegate opens, its all richness venting out the dumptube. i feel sorry for anyone behind me when i vent my anger at the world.
hadden
11
08-07-2013 10:57 AM
JDM kid
11
10-05-2006 02:52 PM
egdriver94
12
08-20-2006 07:21 PM
Tuner Eddy
13
08-06-2005 11:31 AM
SIK IN DA HED
01-06-2004 09:24 AM
Quick Reply: car blowing out white/blue smoke
