cooling fan- most common part that fails?
What is the consensus on cooling fans that don't run at all:
What is the most common component that fails?
Relay
Thermostat sensor
not bleeding the coolant?
Thermostat?
or?
Relay
Thermostat sensor
Thermostat?
or?
Re: cooling fan- most common part that fails? (flyinga)
Cooling fan problems are usually the fan itself (worn motor brushes), or faulty thermswitch which causes the fan to engage. I've had both problems on high mileage 90 EX.
good luck
good luck
zx92027xz
16
07-10-2013 12:52 PM
truejdm86
11
05-02-2011 06:33 AM
bernard_s3
03-11-2011 04:45 AM
