Does your check engine light come on when the oil is low?
Old 11-30-2004, 10:33 PM
Circuit Star-29's Avatar
Default Does your check engine light come on when the oil is low?
The check engine light came on yesterday in the RSX. I couldn't think of what it might be so I checked the fluids and the oil was a quart low. I did change the oil a week ago and can't remember how many quarts I put in...I was in a hurry...(you shouldn't do things to your car when your in a hurry). So, I reset the ECU and the light hasn't come back on...So, has this happened to anybody else or should I take it in to get looked at?
TIA
Old 12-02-2004, 11:23 AM
kseriesDC5's Avatar
Default Re: Does your check engine light come on when the oil is low? (nathan atwell)
run a diagnostic.. is your car stock?
Old 12-02-2004, 06:26 PM
Default Re: Does your check engine light come on when the oil is low? (kseriesDC5)
yeah, its stock. I know on the b series ecus you could run a jumper and the cel would blink the code but do DC5s?
Old 12-02-2004, 07:06 PM
BlueIntegraBoy's Avatar
I don't think the CEL would come on with low oil. The oil dummy light would, but a quart low wouldn't set it off. It must have been something else.
Old 12-02-2004, 11:23 PM
Default Re: Does your check engine light come on when the oil is low? (BlueIntegraBoy)
Does anyone know if theres a way to do a diag. without taking it to the stealership?
Old 12-02-2004, 11:26 PM
If it comes back on... http://home.comcast.net/~rsxmachine/info/CEL/
Old 12-03-2004, 05:14 AM
I said I don't want a title!
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if theres a way to do a diag. without taking it to the stealership?</TD></TR></TABLE>
If it is stock, why not take it back to thew dealership?
Old 12-03-2004, 06:59 AM
f1nal zeros's Avatar
Default Re: Does your check engine light come on when the oil is low? (Todd00)
New STOCK car, take it to the dealership and use that damn warranty that most of us dont have.
&lt;-- Without a warranty since 51k miles and had the extended warranty. hehe
Old 12-03-2004, 09:46 AM
ekferio's Avatar
it might be just a loose gas cap...if you just reset the ECU, it might not come back on right away but eventually it will
Old 12-03-2004, 12:39 PM
Default Re: Does your check engine light come on when the oil is low? (ekferio)
Warranty has expired Its an '02 and used and the original owner didn't get any kind of extended warranty. The CEL hasn't come back on but thanks for the link to show me how to read it next time.
THanks for the help everyone.
Old 12-07-2004, 05:12 PM
Chopper 2 Hopper
justBLZE's Avatar
Autozone will tell you for free also
Old 12-07-2004, 10:32 PM
AMF Racing's Avatar
Default Re: Does your check engine light come on when the oil is low? (tommy69)
it depends......the check engine light COULD come on due to "low oil." mine in my 02 si did. heres why.......since vtec runs off of oil pressure, and if you dont have enough oil to get the correct oil pres......the check engine light could come on due to a faulty vtec pres switch code. mine did the second day after i bought the car. took it back honda ran the diag and it came up with vtec pres switch failure. they were about to order the swithc, when the mechanic checked the oil. it was 2 quarts low, he filled it up reset the ecu and poof no more codes. then he turns to me and asks why i didnt check the oil, i was like yo ******* isnt that YOUR job the car has freakin 22 miles on it for gods sake the oil was the last thing on my mind.
Old 12-09-2004, 12:08 PM
Default Re: Does your check engine light come on when the oil is low? (AMF Racing)
LOL, I haven't seen the check engine light again so I think its good. Gotta love factory mechanics.
Nukin
04-29-2018 09:36 PM
CBoardman
02-04-2008 04:03 PM
slayerfromhell212
01-01-2007 02:26 AM
EuN_TeK
05-27-2003 01:16 PM
Quick Reply: Does your check engine light come on when the oil is low?
