SRS light on what does it mean what should i do
Old 11-13-2004, 05:47 PM
94_del_sol's Avatar
Default SRS light on what does it mean what should i do
Old 11-13-2004, 06:00 PM
k-cerez's Avatar
Default Re: SRS light on what does it mean what should i do (94_del_sol)
take it to an autobody shop and they will have an air bag specialist reset the "brain" computer for about 100 dollars
Old 11-13-2004, 06:49 PM
miahmouse's Avatar
when did it come on? have you had the wheel off, dash off, disconnected any of the airbags. it's pretty much saying that there's a short in the system, or disconnect. if the car was turned on with an airbag unplugged the light will remain...
Old 11-13-2004, 07:04 PM
chads's Avatar
Default Re: SRS light on what does it mean what should i do (miahmouse)
just take the cluster out and remove the light bulb. but leve the yellow plug in so the bags will still work
but dont listen to me.
Old 11-13-2004, 09:43 PM
pancake56's Avatar
Default Re: SRS light on what does it mean what should i do (chads)
means your airbags will not deploy if you crash hard. should really fix it.
Old 11-13-2004, 10:29 PM
jumpmann23's Avatar
Location: Your really lame if you dock my points, WA, 98033
i believe you can check the srs light just like the CEL's. it throws codes. find out what code its throwing and look it up.
Old 11-15-2004, 10:10 PM
chads's Avatar
Default Re: SRS light on what does it mean what should i do (Jumpmann23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jumpmann23 &raquo;</TD></TR><TR><TD CLASS="quote">i believe you can check the srs light just like the CEL's. it throws codes. find out what code its throwing and look it up. </TD></TR></TABLE>
thats something i didnt know. can anyone confirm this??
jhaag115
08-08-2009 12:41 AM
Slava.
10
04-29-2006 07:33 PM
vladd
15
07-17-2003 12:52 PM
B16Hatchcx
07-12-2003 07:30 AM
AcCoRd_HyBrId
05-11-2002 09:58 PM
Quick Reply: SRS light on what does it mean what should i do
