AutoMeter Sport Comp Tachometer Install
Old 09-23-2004, 04:38 PM
DarkBB4's Avatar
Default AutoMeter Sport Comp Tachometer Install
Hey i just isntalled my tachomter and for some reason its not accurate at all... Like when its at 2k rpms (stock tach) its up to lik 4K rpms on the autometer tach....
now, the instructions say to clip the Brown and Orange Wire on the back of the tach.. but On mine.. theress only a brown and a blue?? WTF? I tried clipping one, and it was the same.. then i clipped the other and Nothing changed... It's wierd because it seems as tho i could pull those wires out if i wanted (they feel loose)...
I tried every combination of the wires and its off every time
This thing was "new"... waht could be wrong
I tihnk i wired it right cause the RPM's DO read, but they're too high
Old 09-23-2004, 04:43 PM
UJLSMoFo's Avatar
Location: east coast performance and tuning, jacksonville, nc
Default Re: AutoMeter Sport Comp Tachometer Install (DarkspeedVtec95)
were are you pulling your signal from. try the blue wire next to the hood prop. it should be black tap to the harness
Old 09-23-2004, 04:45 PM
DarkBB4's Avatar
Default Re: AutoMeter Sport Comp Tachometer Install (UJLSMoFo)
from the ECU.. is that wrong?
Old 09-23-2004, 04:50 PM
UJLSMoFo's Avatar
no, perfect
Old 09-23-2004, 04:54 PM
DarkBB4's Avatar
wtf this is soo fricken messed up..
any ideas?
Old 09-23-2004, 05:04 PM
UJLSMoFo's Avatar
dude, its hard to say, you should only have to cut the to wires for 4cylinder. some times the tach has to been calibrated for a specfic car.
Old 09-23-2004, 05:14 PM
DarkBB4's Avatar
well the instructions like didn't hav ethe correct colors or anything....
I clipped both the wires and its Still messed up
Will resetting hte ecu? hae anythin to do with it.. (just disocnnect the battery)
after i clipped them , is there any other Prepping i have to do... just set the shift light?
i read somewher that ur supposed to like Hold in the top button and turn the car on, then it should read 2k and then go up 1 K per 2 seconds... (without revving or anything)... Then u shoul set it at 2k.... wtf
this is pissing me off
Old 09-25-2004, 03:40 PM
PrettyLude's Avatar
try putting the blue wire together, and make sure to check all ur connections
Old 09-25-2004, 04:44 PM
DarkBB4's Avatar
Default Re: (PrettyLude)
called automter.. i know what the problem is.. htanks
Old 09-25-2004, 09:41 PM
PrettyLude's Avatar
what was the problem
stanzione88
10-04-2008 01:18 PM
CLE
12
10-31-2007 07:31 PM
c_buz
01-19-2005 05:58 PM
Civicse
77
12-15-2004 05:13 PM
neutron91
02-16-2004 10:57 AM
Quick Reply: AutoMeter Sport Comp Tachometer Install
