Can a f23a fit in a 96 s prelude
Old 07-24-2014, 03:13 PM
Hon.Don.Na.Da's Avatar
Default Can a f23a fit in a 96 s prelude
Hi, I am trying to get a f23a vtec but i don't know if it will can anybody give me sum insight if this could work.
Old 07-27-2014, 06:51 AM
This_thread_sucks_now's Avatar
Default Re: Can a f23a fit in a 96 s prelude
yes
Old 07-27-2014, 09:41 PM
Will i have to make any modifications?
Old 07-30-2014, 05:28 AM
laviathan222's Avatar
Someone can correct me if I'm wrong but I believe you need the rear, transmission, and front motor mounts from the preludes original engine. Power steering won't work without modification. Easiest way for me when I did it was to leave the F series engine harness with the engine it should just plug into the plugs on the chassis. At least 91 accord to 93 lude worked that way. Dizzy can be a pain depending on if your going from external to internal or internal to external. Hope this helps. I've done 2 F swaps into a 93 and a 95 lude. F22A1 and F22B2 I imagine its the same if not similar in a 96 with an F23.
scrubdakiller80
07-29-2016 03:37 AM
shiux
06-14-2006 08:27 AM
stagsitalia1
07-17-2005 09:31 AM
Quick Reply: Can a f23a fit in a 96 s prelude
