2006 Accord V6 PCV valve check?
Old 07-18-2014, 06:07 AM
brian0918's Avatar
Default 2006 Accord V6 PCV valve check?
What's the best way to check the PCV valve on the V6 engine? Can I shake it and listen for a rattle, or is there a better test to do? The oil is running low, but no leaks. I checked one of the spark plugs and it looks fine, no oil on it or damage.
Old 07-18-2014, 12:04 PM
94 accord typeR's Avatar
Default Re: 2006 Accord V6 PCV valve check?
if u use needle nose pliers to pinch the PCV hose u should hear a "click" sound indicating that the valve is working properly and cant figure out what is blocking the hose
pdelo
11-16-2014 09:57 AM
HAccordH22
11-11-2012 02:30 PM
venom022
12-28-2009 09:20 PM
swertepinoy
10-12-2009 02:50 PM
itsjustmeME
03-30-2008 06:18 AM
Quick Reply: 2006 Accord V6 PCV valve check?
