You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
New to the this so im hoping I am posting in the correct thread. I have a 91 honda civic with a swapped ls b18a1. I got it thinking there was a blowen head gasket. It was odd tho only white steam/smoke would come out when i turn i drove it two hours and dident have any smoke or overheating. but when i turn white steam/smoke would come out in massive amounts. So i took the head off put a new gasket on started her up and my whole car shakes and it sounded like a diesel truck on idle when i gave it gas it sounded fine. took it around the block a few time did some turn n white smoke agian... Did a compression test and #4 cylinder was only pushing 50 psi and the other three where holding around 175. I took my head off and my valves looked fine i put water in and it held. the other thought was maybe bad piston ring but i took a lot on the walls and there was no marks or scratches. i dont see why a pistion ring would go out just like that either because it was fine before. i thought maybe it was the head gasket because i did not do the torque sequence order. so i out a new one on and did the order. started it up nothing. did a compression test agian. #4 cylinder 25 psi the other three are at about 90 psi... What could be going on???
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way.
Copyright/trademark/sales mark infringements are not intended or implied.
