Swapping 00 B16a2 into 96 Civic hatch - need help
Old 09-12-2011, 10:01 PM
  #26
rhymeshark916's Avatar
Default Re: Swapping 00 B16a2 into 96 Civic hatch - need help
Originally Posted by my1stek
Well, I called the ref station and they've been busy all day... but yeah, I know almost everything I need. Just need to figure out if I can use my radiator and what hoses. Also, what a/c condensor I need.
Yes they can be "backed up". Just have to put your phone on speaker and have fun with your XBOX. So, what did they say? Like I mention before, it is practical to source a P30 ecu. Look to spend around $200. There's a dude selling his for $500 at the Norcal Marketplace. If you think it's worth it. I'm not advertising for him. I just think he's a b*tch for doing that.
Old 09-17-2011, 09:11 AM
  #27
my1stek's Avatar
Hey thanks for putting up with my **** and finally I've decided to go k-series. I know what's involved and what I need and the costs. thanks to k20.org I've found out the info I need. So next week I'm picking up the motor and some parts. Pretty soon I'll post up a build thread and a write up w/pics of how to BAR it. So yeah, thanks again!
Old 09-17-2011, 09:19 AM
  #28
92lxsleeper's Avatar
he can and HAS to run the si ecu. in california the ecu code has to match the engine code if i remember correctly. and the transmission needs to match too i think.
Old 09-18-2011, 03:59 AM
  #29
Oh really?
Old 09-18-2011, 05:17 AM
  #30
jdmcertified909's Avatar
Originally Posted by rhymeshark916
Oh really?
Yes he needs to run the matching ecu. Tranny doesnt matter
Old 09-18-2011, 10:35 AM
  #31
xxSOLxx's Avatar
Not 100% sure but couldn't you run 96-98 ex engine harness with stock 96-98 dx cabin harness and just use a obd2a to obd2b jumper harness to hookup the 99-00 si ecu. Well this work? Anybody know??
if u keep ur sock dx radiator then
94-01 gsr for lower radiator hose
94-97 del sol for upper hose
Old 09-18-2011, 02:06 PM
  #32
Cap'N Chronic's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Check out the FAQ thread. It has ton's of helpful info for swaps.
Old 09-18-2011, 04:08 PM
  #33
bunkrd you's Avatar
its much easier and cheaper to add vtec to your harness trust me it wasnt worth the 200+ dollars for the ex wiring harness just because it has an extra two plugs
Old 09-18-2011, 04:11 PM
  #34
bunkrd you's Avatar
Just keep the ecu obd2a with either a 96-98 gsr ecu or a 96-98 p30 del sol ecu. Add vtec to your wiring harness.
Old 09-18-2011, 04:40 PM
  #35
ek9_B18C's Avatar
I dont know if you have found a harness but I have a obda2 harness that came off a b18c forsale. So all you would need is a ecu adaptor and you can use your si ecu.
Old 09-18-2011, 05:25 PM
  #36
Master Detailer
98civdx's Avatar
That will cause Check engine lights, which is a automatic fail.
Old 09-18-2011, 08:04 PM
  #37
my1stek's Avatar
Thanks or input, but guys I'm doing this^^^
Old 09-18-2011, 11:39 PM
  #38
Oh really?
Old 09-19-2011, 06:09 AM
  #39
xxSOLxx's Avatar
Post Re: Swapping 00 B16a2 into 96 Civic hatch - need help
So just stick with a 99-00 p2t si ecu and just mod the harness???
Will this setup throw a cel???
Old 02-17-2012, 07:19 AM
  #40
HondaScene's Avatar
Can always get a p28 for like 100 or cheaper and get the basemap changed to a p30 works fine!
my1stek
21
09-11-2011 04:15 PM
my1stek
09-05-2011 10:36 PM
Quick Reply: Swapping 00 B16a2 into 96 Civic hatch - need help
