Swapping 00 B16a2 into 96 Civic hatch - need help
Hey everyone, Im new to swaps and I've been searching for help with this swap which has been a pain because I live in CA and need more specifics.
I know this is a common swap, but Im new to this and I'm still searching, but I need some help. I have some quite a few questions and hope you guys could answer them.
I have a 96 cx hatch btw... and putting the 00 si motor in it
Transmission: I heard there's an adapter i can use, since its a cable tranny?
Also, do i need any mounts for it or will i use the D-series mounts?
Fuel lines/pump/injectors: What will I need to do for this?
Radiator: Which one do I use? or can i use my stock one? also will it bolt right in?
Ac Condenser: Which one do i use? Does it hook up fine without modification?
WIRING: Can I use my stock harness? What modification will I have to do? Will all my electrical plugs fit? How do I wire V-tec
Ecu: How does it hook up? Do i need an adapter?
EMISSIONS: What do I have to do to pass emissions?
I had one response where he said id have to do something will my fuel tank. Idk CA is just a pain in the ***.
If any could answer these questions for me it would be GREATLY APPRECIATED. This has been bothering me for the past 2 weeks. Thanks again!
Re: B16a2 Swap Help
Fuel lines/pump/injectors: use the injectors on the b16 motor.fuel lines and pump will stay the same.no need to change them.
Radiator: reuse your stock one.
Ac Condenser; will work with both swaps.
Ecu: get a chipped obd1 ecu and a obd2a to obd1 jumper harness
WIRING: you can use your stock harness but you will have to change the iacv from a 3 wire to a 2 wire. vtec and the oil pressure switch will require you to add 2 wires from the engine to the ecu.
Transmission; i don't like cable trannys, i would sell it and get a hydro tranny. makes thing alot easier.
EMISSIONS: put a cat converter and a muffler with a good tune on the ecu.
Re: B16a2 Swap Help
well the ecu from the si swap wont work. your gonna have to find a 96-98 stick vtec ecu so it will work with your swap. and you will never get the full potential of that motor with that ecu
Re: B16a2 Swap Help
the plugs are different in the inside. if you wanted to use the si harness you have to change the harness behind the dash so it will match the si harness. the green plug by the ecu changes...
Re: B16a2 Swap Help
so, id need the 98-98 ex harness then? and i would still have to do some modification?
oh for the radiator, wouldnt i need a bigger one because the motor is DOHC
Re: B16a2 Swap Help
yes but that a easy fix you just have to extend the vtec wire and the oil pressure swith to reach the new location. the iacv is there already, you just need to change the plug from a 3 wire to a 2 wire., and the radiator is the same from 92-2000. half size.
Re: B16a2 Swap Help
If he can run a jumper, peice of cake, just buy a obd2a to obd2b jumper harness. If not, he's going to have repin/modify the plugs/harness to accept the new ecu. He could also switch out to the 99-00 harness. Dash/Engine would need to be switched. IMO, this would require changing the Climate control to the 99-00 type.
OP, why are you going to run cable tranny? it's going to create a large headache. The hatch is hydro, as is the SI. Keep the car hydro.
Re: B16a2 Swap Help
So the stock si tranny is hydro? i heard it was cable...oh well
umm do you have any links to like a write up or something I've been searching for all this info for a whileee and havent come up with much...
Re: Swapping 00 B16a2 into 96 Civic hatch - need help
Judging by your post, you need to do a lot of searching and reading. There are info here that you can check out and read up on under FAQ. Being that your in CA as well, swapping can be tricky and if this is your first time. Hence like BAR referee. I just recently BAR'D my EH with a B18C1. So I'll help you what I can on that part.
Here's a list of what you need:
1) 99-00(EM1) Civic Si B16A2/S4C
2) 99-00 Civic Si axles/Rear T-mount
3) 96-00 Civic Ex/Si catalytic converter (if you can find it with the swap, great)
4) 96-98 Civic Ex engine harness
5) 96-98 Del Sol DOHC VTEC P30 ECU
To make things easier, I would find a donor car that is wreck or just want to part out the whole engine swap. This way you won't be missing any knick knack parts and everything is original down to it's distributor and nuts and bolts. Also, try to find one that is low mileage. Take your time, get the right parts and do it right the first time.
These are the basics you need.
Here's the number to the ref station. 1-800-622-7733, I think someone on this board passed with a jumper harness. You can get info on that.
Well, Ive read it's important that I take receipts with me to show the ref, for proof it's legit and not stolen. I've also read that I need other brackets to mount the motor and tranny. And for the ecu, wouldn it be better to run the si one because thats something the ref would be looking for right? As for my exhaust post, I mean I have no problem installing a catback later, I just want to go and pass with a stock exhaust first.
Del sol's ran the b16a3, which is almost the exact same as the b16a2.
Running the SI ecu will give you a headache, unless you want to swap all 99-00 stuff in.
Technical Hero
Well, I called the ref station and they've been busy all day... but yeah, I know almost everything I need. Just need to figure out if I can use my radiator and what hoses. Also, what a/c condensor I need.
These questions get asked every day, that's why they're on the FAQ.
Entire A/C system on both cars are the same except for the compressor. You'll need a bracket from a Del Sol VTEC in order to keep your A/C COMPRESSOR, not condenser. The condenser is the other radiator look-a-like that's on the driver's side of the car. You'll need the bracket, pulley, and belt. The code for a Del Sol VTEC is P54. Just look for a P54 A/C bracket and pulley.
