Best way to fix a stripped block head stud hole (idk)
Old 01-06-2012, 06:08 AM
Dioxine's Avatar
Default Best way to fix a stripped block head stud hole (idk)
Ok so i dont know what to call it. But the threads in the block where the head stud goes into are crossthreaded and stipped. What is the best way (if any) to go about fixing this. Or should i just trash the block and get new one. Thanx in advance.
Old 01-06-2012, 04:43 PM
hondasdohc's Avatar
Default Re: Best way to fix a stripped block head stud hole (idk)
M12-1.25 thread tap get it at your local auto store and hopefully it works but before you put the head back on put the stud in the hole that you fixed.
Old 01-06-2012, 04:49 PM
per4mance's Avatar
no, if the threads are stripped the material is gone. Best way to fix it is a time-sert or what is also known as an insert. Google it and that would be the best way and will last.
Old 01-06-2012, 05:02 PM
hondasdohc's Avatar
Oh yea your right i feel dumb. Yeah get the inserts.
Old 01-06-2012, 05:36 PM
Dioxine's Avatar
See thats what i was thinking, would they actually be able to withstand the pressure though without moving. Im worried that as soon as they get force on them they will start to pull out.
Old 01-06-2012, 05:38 PM
Dioxine's Avatar
Ok so i just looked at that and ive never seen anything like that before, i was thinking something like a hetacoil that looks like it will be a lot better
Old 01-14-2012, 11:28 PM
Divers's Avatar
Time-set makes a honda head stud repair kit. We have it and have used it on damaged sleeved blocks that make over 650hp. It works great.
Old 01-15-2012, 07:12 AM
Dioxine's Avatar
Do you know where i can find said set?
Old 01-15-2012, 07:09 PM
Divers's Avatar
It's pretty expensive (about $400) for only one block. If you don't want to buy it I can have Shawn send you a UPS call tag for your block and do it for you. PM me if interested.
Here's the link of said kit. Just google shopping search and they are all over.
http://www.timesert.com/html/honda.html
jiggacivic
09-25-2014 11:13 AM
turbotime
13
11-05-2005 06:43 PM
the DA in HONDA
05-10-2005 09:16 PM
RacnGSR
08-17-2002 11:40 PM
275Performance
02-01-2002 09:13 AM
Quick Reply: Best way to fix a stripped block head stud hole (idk)
