*Official H/T OFFROAD/LIFTED CR-V thread!*
#3252
Re: *Official H/T OFFROAD/LIFTED CR-V thread!*
Whoops, yea, new complete strut/spring kyb strut+ combo.
I used kyb’s warranty to get all 4 corners new. The ones before were the same kyb’s and the rears sagged and sat at like 30” while the fronts were at 31”.
still waiting to get my FLCAs back from the shop because I had new bushings pressed in. So I won’t know how it’ll sit until I get those installed.
The top mounts of my old front sets were torn to ****. So on the new fronts, I ordered new OEM top mounts and installed them on the new struts cause I knew the KYB ones suck.
Nothing was wrong with my old sets except the torn front top mounts. Maybe I should just replace the top hats on the old fronts, throw the spacers on the old rears and call it a day?
#3253
-Intl Steve Krew
New springs are going to need to settle as well.
Once the springs have settled it’ll probably sit a bit better.
Even new springs can make your CRV look like it’s “lifted” compared to all of the sagging stock suspension (mine included lol)
#3254
Got everything back on and its sitting perfect. The rear isnt high anymore like that first photo I posted. Pretty much did a front suspension overhaul. 1" aerogenics spacers in the rear to level out with the front. Car feels ******* happy with the results.
- New OEM FLCA bushings due to cracking/splitting
- 555 Ball joints
- KYB strut+ all around. I replaced the front top mounts + bearing with OEM.
^kyb strut mounts suck. no more clunking noise after replacement.
- 555 Ball joints
#3255
Looks nice. Its incredible how much the suspension will settle out after being installed. My CRV looked like I lifted it so much farther once I finished. A short drive down the road settled it out good. Makes doing an alignment at home difficult, when you have to lift the car to align it, which throws it out of alignment until it settles again.
#3256
Im looking to get a new set of rims for my 99 CRV. In short, I am looking for rims that are 15x7 with Offset of between 0 and -10mm. I was looking for recommendations on what to get. I want a Black rim, and I prefer something with a more solid look. I currently have Steel D Window rims, but they might be fake, and all 4 are bent now. I decently like how they look, but I dont need exactly that style.
#3258
#3259
#3260
Dang.. Just noticed I haven´t been here since the pandemic started!
Still running the V, a little bit taller now though, 2" in the rear and 1.6" in the front.
New wheels and a different light setup.
#3262
#3263
Sorry guys for my longs post! I am kind of new to the forum, and reading through the years of discussion took me actually quite some time 😅 Hope there are some CR-V people still out there...
That's very peculiar. Any suggestions for a sway bar upgrade for 2nd gen CR-V?
This is what I'd like to know as well. I mean, what's the difference between HRG Engineering -style steel weldment in comparison to some CNC/machined aluminium spacers?
What sorts of power upgrades can you have by replacing the muffler? Any muffler suggestions?
I installed Dobinsons 40 mm lift spings, but the height barely changed 😳 Any ideas for that...? I still had to install 20 mm lift spacers at the front, and 30 mm at the rear to reach a total lift of 2 inches.
What do you make of Insane Shaft's axles (https://insaneshafts.com/product-cat...02-2006-crv/)? Are they any good, or should I just stick to the OEM ones? At least they're from the very pricey end... 😅
I bought mine from Etsy, custom made: https://www.etsy.com/fi-en/listing/1...ade-sparecover
LoL, that's what I did, and all I got was 2 inches worth of lift. Dunno why though ... after installing the Dobinsons 40 mmm lift springs, I didn't get any lift at all. Therefore, I had to install +20 mm lift spacers to the front, and +30 mm to the rear, respectively.
Dobinsons does sell front lift springs for the 2nd gen. I've got 40 mm but unfortunately, they lifted barely nothing. I guess each car is an individual, but for what might that be...? Had to insert another 20 mm raiser blocks at front to achieve my goal of 50 mm raise. Seems like the raise starts to kick in only after a certain treshold...
Wow, I'd love to hear more about those!!!
Tell me more about the transmission drop spacers: do I need them besides the subframe dropkit? Or moreover, do I need ANY sort of drop kit in the first place? You see, there's some conflicting information between HRG Engineering and Aerogenics out there. According the former, for lifts less than 2" it is not necessary; according to the latter, however, a drop kit is included in their 1.5" / 2.0" complete lift package (https://aerogenicsusa.com/collection...e-lift-package).
Then, why does Aerogenics include a subframe drop kit in their 1.5" / 2.0" complete lift package (https://aerogenicsusa.com/collection...lift-package)? HRG Engineering tells a different story, saying such would not be necessary with those lifts, though...
Is this true? I thought it'd give clearance for bigger, more beefy tires...
Short drop kit, that sounds interesting. They've still got that...?
I just did 40mm Dobinson Springs and have run 215 75 15 General Grabbers for years now, it is a great all around setup IMO!
Does anyone know where you could get hold of the spare wheel cover 08U02-S9A-100A?
Oh my god this is hard. I had to return the front OEM springs because the online retailer got it wrong; OEM doesn't sell front springs for the 2nd Gen Honda CRV. So I got 1.5" spacers from HRG instead. Almost finished with the front lift, but re-assembly took forever and it's looking like I may have to remove the sway bar. From reading about 2nd gen front lifts, this sounds typical?
The lift is a 2" HRG suspension lift and and then combination of the 2" lift and new tires made it more like a 5" lift, So I have some axle vibration. I also bought the HRG engine and trans drop spacers that didn't take care of it, so I have an order in for the HRG 1" subframe kit, and that should take care of it.
I have a 1999 Honda CR-V 5-Spd Manual. I have 15x8 Rims with -3.75 inch backspacing, running 30x9.5 AT Tires, I have "2inch" HRG lift spacers front and rear. The rear spacer is 2inch, the front is 1inch. Not sure how that measures in actual lift height, the car was already modified (poorly) when I got it, so I dont have a comparison to true stock.
The other consideration was getting a subframe drop kit from HRG. They have a short drop kit, which I would hope is enough, since the full drop kit sounds like it is only needed if you lift higher than 2 inches.
#3267
They look like the stock Honda rims that came on my 2004 Element. Mine are 16 inch. I have them in storage as I put American Racing Torque Thrust 2 on them.
#3268
Hi all. Just got an 06 CRV SE and one of my struts is going out, so I figured I'd just swap them all out. Never really had any interest in doing nice upgrades on my car until now so I'm a little lost.
Originally I was planning on doing a 1" or 1.5" lift with spacers, but now I'm leaning more towards a spring lift. Below are the struts and springs I plan on going with, but I understand I will also need strut mounts. Was probably going to go with OEM since I hear the KYB ones suck. Will I need anything else for the strut assembly? I don't wanna have to reuse anything from the old struts. I'm also planning on replacing some smaller stuff like the ball joints and tie rod ends while I have everything taken apart.
Struts: https://www.shocksurplus.com/product...006-honda-cr-v
Springs: https://exitoffroad.com/product/dobi...40mm-1-5-lift/
Mounts: https://www.hondapartsnow.com/genuin...=pd:4223541,11
https://www.hondapartsnow.com/genuin...=pd:4223541,10
#3270
Make sure you’ve got a manual or something when putting together the strut assemblies because they are supposed to be clocked at a certain angle. You’ll understand when you see it.
It looks like you’ll need a few rubber pieces though. Like the dust boots, and cushions for the springs. If you go to your Honda mount link and scroll down, look at the diagram and you’ll need #s 2, 7, 8, 9.
#3271
Struts, springs and mounts look good. Definitely stay away from the KYB mounts lol. I went through 2 sets before switching brands and I’m all good now.
what brand mounts did you switch to?
