Tips on removing the climate control?
Old 04-23-2004, 02:07 PM
is3oo's Avatar
Default Tips on removing the climate control?
Is there anything I need to know? Do I just pull it out?
Old 04-23-2004, 02:10 PM
Audi A4's Avatar
Default Re: Tips on removing the climate control? (Type-Rizzle)
there are screws behind the hazard and defront bottons..also theres a cable connected
Old 04-24-2004, 03:37 PM
is3oo's Avatar
Default Re: Tips on removing the climate control? (DRAG lll INTEGRA)
Thanks.
Old 04-24-2004, 03:41 PM
Chris's Avatar
cable is located on the passenger side of the console, behind where the lighter is..
Old 04-24-2004, 08:42 PM
is3oo's Avatar
Default Re: Tips on removing the climate control? (Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris &raquo;</TD></TR><TR><TD CLASS="quote">cable is located on the passenger side of the console, behind where the lighter is..</TD></TR></TABLE>
That shouldn't be a problem since I'm missing the whole ashtray and lighter console.
Old 05-03-2004, 10:24 PM
is3oo's Avatar
I get what you guys were saying now. How do you disconnect that cable which controls the temperature?
Old 05-03-2004, 11:24 PM
ilovemyhonda's Avatar
If you look under your dash on the passenger side you will see a cable connected to a metal post. Just pull the cable off the post and you should be fine.
Here are some pictures from team-integra.net
Old 05-04-2004, 12:20 AM
Dc2 Powered's Avatar
why do you want to remove it? going add boost controler or a gauge or controler of some type?
Old 05-04-2004, 01:44 PM
is3oo's Avatar
Default Re: Tips on removing the climate control? (ilovemyhonda)
Thanks for the pic. It was very helpful. Now do I pull the whole climate control out with the cable attached to it?
Old 05-04-2004, 06:21 PM
sykotic's Avatar
yes, the cable is attached to the cold/hot dial, its a real bitch to get the 3 pieces of that climate control apart to take the cable off of the climate control unit, just pull the cable out with it, take note of how the cable is routed through the center console for when you reinstall it, otherwise you may not be able to reach full hot or cold.
turboman
11-16-2005 09:26 PM
stevescivic
08-11-2005 06:28 PM
yOnKiNaToR
03-11-2005 04:12 PM
jhota
11-20-2004 12:15 AM
itsJDMyo
10-30-2003 05:39 PM
Quick Reply: Tips on removing the climate control?
