HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions
Old 04-11-2004, 07:38 PM
Civiclx's Avatar
Default HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions
did a search, I have an autometer boost gauge and a blitz dtt turbo timer that reads boost in khpa, does anyone know how to convert these measurements?
Old 04-11-2004, 07:44 PM
TurboTegB18c's Avatar
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (Civiclx)
1 bar is equal to 14.5 psi. so u take whatever bar u get and multiply by 14.5 and that's ur psi.
Old 04-11-2004, 07:54 PM
alpha's Avatar
http://www.supramania.com/conversions.html
Civiclx's Avatar
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (TurboTegB18c)
is bar the same as hkpa? because my turbo timer reads it in hkpa? i thought bar was kg/cm^3
Old 04-11-2004, 07:59 PM
Civiclx's Avatar
looks good, but what about hkpa and mpa (wrx stock gauges)
Old 04-11-2004, 10:00 PM
EFb18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx &raquo;</TD></TR><TR><TD CLASS="quote">is bar the same as hkpa? because my turbo timer reads it in hkpa? i thought bar was kg/cm^3</TD></TR></TABLE>
14.5psi = 1 bar
1 bar = 1.0197 kg/cm^2
Old 04-11-2004, 10:05 PM
Hoosier Daddy's Avatar
For the V/SAFC guys:
(kg/cm^2) = PSI
.035 = 0.5psi
.070 = 1.0psi
.105 = 1.5psi
.141 = 2.0psi
.176 = 2.5psi
.211 = 3.0psi
.246 = 3.5psi
.281 = 4.0psi
.316 = 4.5psi
.351 = 5.0psi
.387 = 5.5psi
.422 = 6.0psi
.457 = 6.5psi
.492 = 7.0psi
.527 = 7.5psi
.562 = 8.0psi
.597 = 8.5psi
.633 = 9.0psi
.668 = 9.5psi
.703 = 10.0psi
.773 = 11.0psi
.843 = 12.0psi
.914 = 13.0psi
.984 = 14.0psi
1.00 = 14.23psi
Old 04-12-2004, 02:12 AM
MiraiZ's Avatar
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (Hoosier Daddy)
there must be tons of conversion calculators on the net
Old 04-12-2004, 05:26 AM
Honda Hick's Avatar
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">there must be tons of conversion calculators on the net </TD></TR></TABLE>
I like this site the best. It converts EVERYTHING.
http://www.convert-me.com
1 psi = 6.895 kilopascal (kPa) or 68.95 hectopascal (hPa) or 0.06895 bar.
I don't see a khPa, but I'm assuming it is kPa.
Old 04-12-2004, 05:32 AM
DaX
DaX's Avatar
Actually,
1 bar = 10^5 Pa, which is approx. 1 atm, or 14.7 psi.
Just do a google search on pressure conversion, there are tons of websites.
Old 04-12-2004, 07:19 AM
Civiclx's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Actually,
Just do a google search on pressure conversion, there are tons of websites.</TD></TR></TABLE>
keep in mind that is atmospheric pressure which is completetly different than a manifold vacuum
ICeDoUt
12-25-2007 07:55 AM
CarAudioPro
12-31-2005 11:10 AM
{StatuS ChecK}
09-10-2005 07:06 PM
TheHater
12-02-2002 03:43 PM
VTC_CiViC
09-07-2001 09:43 AM
Quick Reply: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions
