Anyone know what cam this is
Who is Mr Robot?
Re: Anyone know what cam this is
Yea measure the lobes for lift
Here's how you do it:
Get a set of dial or digital calipers
Measure the base circle (where the lobe hasn't started, the circular part) then measure the vtec lobe from the bottom of the cam to the top of the lobe. Subtract the base circle from the lobe measurements and there's your gross lift. You can search on that along with the numbers on the cam and figure out what they are
Also, clearer pictures of the ends of the cam would help a lot. As those are impossible to read
i was in the same situation 2 days ago..i got done a lot of research..came out it was a Comp Cam 57300....mine has the same exact etchings. Crane, Zex & Comp Cams uses identical etching process...good luck
Who is Mr Robot?
what about the cams Edelbrock made?
I would simply start emailing every cam company we've listed with the pics and the numbers off the cam until you figure it out
List of companies:
Blox
Rocket Motorsports
Brian Crower
Crower
Edelbrock
Comp
Zex
GSC (doutful it's one of theirs)
Web
Jun
Skunk2
Laskey Racing (they made custom grinds)
that is all I can think of at the moment. like I sad just shoot them and email and include the motor/engine code you're using, pics of the cams (lobes as well and any identifying marks anywhere on the castings) as well as the pics of the etched numbers (try taking a pic with better focus for the numbers) then list the numbers separately (type them out... duh lol)
and hope for a response
I'm sure I'm forgetting some companies
also something I just thought of, they could be OBX cams or any of the typical vtec cams peddled on ebay (I.E. cheap copies)
List of companies:
Blox
Rocket Motorsports
Brian Crower
Crower
Edelbrock
Comp
Zex
Web
Jun
Skunk2
Who is Mr Robot?
it already had duration listed
I can measure lobes with a pair of calipers and find cam lift... hell anyone can do it
what you won't know, even if a cam guy measures both cams is center line, LSA, lift at the valve, and so on... you can only get gross lift at the cam, it's not like measuring a sohc cam or a pushrod v8 cam... you need the cam card from the cam maker to truly know what you hae
thanks everyone,
i forgot to post what my search results where, i contacted the guy who owned the car when he put those cams in and he ordered a stage one comp/zex cams and installed them in the car and then sold it,
but after some research i found out he got the wrong cams, these are the comp/zex 59300 so great cams but the motor had stock valvetrain so i guess it's luck that the motor is still ok after 20.000km
after looking over this again, i'm thinking that these are just comp stage 1 cams 57100
but here are some photos, see if you see anything
top of the intake cam,
Top of the exhaust cam, stamped A25 and there is something ethced in there but it's so faded that i can't see it, could be 57103
exhaust cam
intake cam
both cams
exhaust cam
intake cam
both cams
Who is Mr Robot?
you could always try an acid reagent to bring out those faded numbers, basically acid etching, brings that stuff to the surface. similar to how criminalists bring back destroyed serial numbers on firearms
its a decent amount of effort but if it helps you figure out what they are... then I'd say time well spent
That intake cam has a 260 degree duration, I can't see the exh but it looks like the exh is stamped too. Those aren't crane or comp, they didn't make anything that big, that MIGHT be a custom spec cam from someone like schinder or something.
