2001 Accord cranks but will not start, please help!
Old 01-28-2013, 09:58 AM
kcollings's Avatar
Icon3 2001 Accord cranks but will not start, please help!
My 2001 Accord suddenly will not start. We are on vacation and supposed to be driving home today but can't find the problem. It cranks but never starts. I checked the fuel pump which seems to be working, and it has spark. I sprayed starter fluid in the intake and still won't start. I also tried resetting the computer on the off chance that the immobilizer was the problem but no luck. I have run out of ideas. Anyone have any suggestions?
Old 01-28-2013, 10:14 AM
jdowen2's Avatar
Default Re: 2001 Accord cranks but will not start, please help!
Chek engine light on? If so, check for codes.
Old 01-28-2013, 10:40 AM
SlowDA9teg's Avatar
Ignition control module inside your dizzy? Main relay?
Old 01-28-2013, 06:05 PM
kcollings's Avatar
I tried all the basics (i.e. plugs, cap and rotor, wires) related to spark which leads me to think its a fuel issue. It seems like I have fuel pressure at least up to the fuel rail. How would I check the ignition control module?
Old 01-28-2013, 07:13 PM
kcollings's Avatar
So I just noticed that my check engine light is not on when I'm cranking it. Help...
Old 01-28-2013, 08:44 PM
f1drivr's Avatar
Take one of your plugs out, put the plug wire back on and ground the bottom of the plug to the block or valve cover while someone turns the car over with the starter. You should see and hear the plug firing. If not you might have a bad coil.
Old 01-28-2013, 08:50 PM
kcollings's Avatar
Well I just got the obd codes, and they translate as follows: misfire, fuel, ccm, cad. conv., evap, o2, htr, egr. The guy that ran the test didn't give me the specific codes so thats what I have to work with. And I checked all the plug wires, they all are getting spark.
Old 01-29-2013, 02:59 AM
kcollings's Avatar
Could it be the ignition control module? I followed the spark up to that point but haven't tested it yet.
Peter Lopez
11-06-2014 06:14 PM
Felipe_Rdz
05-08-2013 02:27 PM
chickendance
03-12-2012 03:48 PM
leper messiah
08-30-2008 12:27 AM
Big_b_69er
01-24-2002 09:07 AM
Quick Reply: 2001 Accord cranks but will not start, please help!
