How to remove knuckle and replace wheel bearing on a 94 Civic HB DX?
Idk if there is a thread already about this, i looked but couldn't seem to find one, also looked on YouTube and nothing. So if there's already one please if you can link me to it and if a MOD can close this (if there is a thread already)
Anyways first off does anyone know where i can watch a video on how to replace a front wheel bearing on a 94 EG DX.
If not can anyone help me out on replacing it, like a step by step.
Thanks in advanced!
Thanks in advanced!
The Grumpiest
Re: How to Replace Wheel bearing on a 94 Civic HB DX
You sure you looked? This was right on the front page when you posted.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/front-wheel-bearing-replacement-harbor-freight-tool-set-66829-a-2984426/
https://honda-tech.com/forums/showthread.php?t=2984426
actually ya i did see that one, but since i don't have that tool set i made my post because i knew a guy who replaced his not using a tool set like that he used tools he had at his house.
The Grumpiest
Then call that guy and ask him how he did it????
You asked how to change them out and here you go. If you're looking for a way using exact tools that you prefer AND a step-by-step guide WITH pictures, you might be waiting a long time.
had a feeling you were going to say that, if i could i would i wouldn't be posting about it obviously. and about the waiting, it doesn't hurt to try.
If you don't have a press or the tool used at the link, then buy a replacement bearing, remove the knuckle yourself, and then call around to local shops to find the lowest price for pressing the old bearing out and pressing the new bearing into the knuckle.
Ya i have the part i need already, so can i use a flat head and a hammer to pop it off? I called this shop to see how much they would charge me to put it in and they said about $50-$70 does that sound about right?
Last edited by Former User; 05-19-2012 at 05:44 AM. Reason: Keep the discussion civil - text deleted
The Grumpiest
If you want to know if the price "sounds about right" you can pick up the phone a couple more times and call around to a few more shops and do what is called a "price comparison".
Sounds a bit high, especially $70. Call other shops to compare prices and try to pin down a more specific price from the $50-70 shop. Not sure why they they gave a price range.
Here's what you need to know about knuckle removal and wheel bearing replacement:
Re: How to remove knuckle and replace wheel bearing on a 94 Civic HB DX?
thanks Ron and thanks for the detailed picture
k_bster24
Transmission & Drivetrain
08-17-2010 07:34 AM
rear wheel bearing problem.....bearing assy. separated into 2 pieces one stuck on the hub still ...d
japspecjohn
06-19-2005 10:32 AM
