Detailing Auto Detailing and Concours
painted door panels? how to strip the paint off
Old 04-19-2012, 07:33 AM
jlbarrios's Avatar
Icon2 painted door panels? how to strip the paint off
Just picked up civic with light grey interior but they spray painted the door panels black wondering if anyone can tell me how to take the black paint off without messing up the grey color under it. Any advice will help ?
Old 04-19-2012, 07:26 PM
joeshmo's Avatar
Default Re: painted door panels? how to strip the paint off
Depends on what they used to paint the interior. For some stuff, rubbing alcohol and simple green might work and will cause minimal damage.
Old 04-22-2012, 10:49 PM
MidasGuy's Avatar
i would just get new door panels not worth stripping .
Old 04-23-2012, 09:23 AM
jlbarrios's Avatar
Yea I think they just used regular spray can gloss black
But ill try it out thank
Old 04-23-2012, 10:11 PM
Precision Hatch's Avatar
You can also use a hot water mixed with castrol superclean or believe it or not hand cleaner such as go Jo....I had a friend with a similar issue and I used a mix of those..(mix to strengh needed due to paint build up) and just used a simple green soap sponge from the typical dollar store the green side of course and those paticular sponges once wet don't scratch as much as your gonna need somthing with a small abrasive to it to help break down the coats.....since I'm sure its more than one coat ..but use this only to break the surface or the top coating off then switch to more of just the hot water .....HONESTLY!! in my opinion find a cheap part out on craigslist and you gonna find its much easier and cleaner on that approach buddy!!
Old 05-03-2012, 08:22 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Non synthetic brake fluid is mild enough to take the paint off but leave underneath ok.
I would hit up the junk yards for the easiest fix!
Old 05-09-2012, 07:54 AM
rsongt3's's Avatar
get new door panels i hate when we have to fix previous owners **** ups! smh
Old 06-13-2012, 09:16 PM
Tekkno's Avatar
Is it plastic drip( or something like that?) , just try to use rubbing alcohol on some less visible place and see whats going on there
Davidss
Paint and Body
12-19-2010 11:40 AM
twiztid00002
Paint and Body
11-18-2008 07:38 PM
HondaGuy4Life
05-23-2007 04:36 AM
diewnaylomoah
05-01-2007 12:05 PM
teejlc
Paint and Body
04-23-2007 07:20 PM
Quick Reply: painted door panels? how to strip the paint off
