Crv No Spark AFTER 5 speed Swap
Old 02-22-2012, 05:52 AM
Kelvin Racing's Avatar
Default Crv No Spark AFTER 5 speed Swap
5 speed swap was done to my 97-01 Crv and now has no spark.. What are some things that I should check for? When the auto shift lever was taking out we left it in Park.
Old 02-22-2012, 06:07 AM
LDForget's Avatar
Default Re: Crv No Spark AFTER 5 speed Swap
Check all of your grounds (chassis -> block, block - > battery, battery -> chassis). You can do a temp fix by using booster cables. Place one clamp on the battery and the opposing on the block, then place another clamp on the block and one on the chassis.
Old 02-22-2012, 07:03 AM
Thank You, when I get to the shop I will DO!
Old 02-22-2012, 01:57 PM
Phantastic's Avatar
I would also check the ignitor in the distributor in case it burnt out.
Old 02-28-2012, 12:29 PM
MonkeyMagic's Avatar
Since changing a transmission burns out ignitors..
LKSi
06-11-2007 09:30 PM
crdcz03
06-16-2005 07:22 PM
Turbo Powa
12-04-2002 11:21 AM
Quick Reply: Crv No Spark AFTER 5 speed Swap
