how to tell if fuel pump is going out?
Re: how to tell if fuel pump is going out? (PatrickGSR94)
I'm hearing a high pitched whine/hiss from mine, almost like alternator noise (I don't have any interior behind my front seats at the moment). Is this normal or should I be concerned?
there's a test you can do. I dont know the specifics for it but basically you take the fuel line and put a cup to it and measure the flow. For n seconds there should be x volume of fuel. If you are less than normal specs (look it up in a manual) then you know your pump isnt performing how it should be.
Re: how to tell if fuel pump is going out? (tilt)
... measure the flow...
prestonpark
03-15-2006 09:45 PM
Eluzion
04-11-2004 09:51 PM
