Classic Hondas All Pre-1988 Hondas.
1987 crx engine swap
Old 10-01-2011, 07:59 PM
RubberGloveBoii's Avatar
Default 1987 crx engine swap
I have a 1987 crx and I was wondering if anyone can tell me wat engines would swap right in it. And say which one yall think would be the best one and why. Thanx.
Old 10-02-2011, 08:43 AM
projected3's Avatar
Default Re: 1987 crx engine swap
I head if it was carbureted its very expensive to swap if your looking for an OBD-1 engine or anything like that. You have to change all your wiring before you even think of swaping.
Old 10-02-2011, 11:31 AM
Yea thats what I heard too. Its just im not sure what motor to reace the old one with. I want more power and still have that great honda fuel mile.
Old 10-02-2011, 06:17 PM
Gustav129's Avatar
as for swapping right in the easiest, it would be the D16a1 out of an 86-89 Acura Integra. That's what the 84-87 Civics/CRX's came with in foriegn countries.
Old 10-08-2011, 03:10 AM
E-AT_me's Avatar
d16a1 with carbs. :D
Old 10-16-2011, 05:17 PM
xero_xero's Avatar
i have wondered this as well. i would think a d15b7 would be a strait bolt in. i did a b series swap into an 87.
Old 10-30-2011, 09:31 AM
sevendurt's Avatar
not to thread jack but what all in-tales for a b series swap wiring, gas tank and lines, fuel pump plus motor and ecu? just wondering im trying to swap mine?
Old 10-30-2011, 09:41 AM
sevendurt's Avatar
Old 10-30-2011, 09:59 AM
xero_xero's Avatar
here are some pics of the sapw geting wrapped up.
List of general items you will need.
Engine (b20a/b21a are not the same as b20b/b16/b18a1/b18b1/b18c1)
Transmission (cable preferred, but conversions for cable to hydro are available)
Axles (hasport can make and still has some available)
Mounts
Wiring
Ecu
Engine/Transmission
Prelude Engines are not appliacble to this swap information
the wiki is here
Engines can be sourced from 90-01 Intgra, 99-2000 Civic Si, And Crv 95-01. Transmissions can only come from 90-01 integra Manual, and 99-00 Civic Si.
As well, if you request any engine/transmission applicable to these cars for your Local Japaneese Importer, he will provide you with a JDM compatible engine
Axles/Mounts
Hasport Has mounts and axles readily availble.
you wil need a 90-93 intermediate shaft.
94-01 Integra /99-00 Si axles and intermediate shafts are too wide and hit and bind a bit
Hapsort Axles
Hapsort Mounts Hydro or Cable transmission
Wiring/Ecu
Wiring can be transplanted from si Civic/CRX models from 86-91. you will need to depin and repin for the ecu. Dx models are either carbed or Dual Point injection. you may choose to transplant a full obd1 or obd2 firewall harness into the car. a good many of the plus are plug and play. specifics are way to detailed to go into into this post. if you choose to maintain the OBD0 wiring, you can add a jumper harness for obd1 conversion to use a newer ecu. obd0 ecu is only compatible with obd0 Distributor. Obd1 and Obd2 are compatible with either ecu/dizzy combo but not compatible with obd0.
Freemananana
17
05-29-2014 06:58 AM
96-wagon-boy
07-28-2012 05:40 PM
Jeremyyy
02-28-2011 01:34 PM
Neptronix
26
05-30-2007 07:06 PM
blacksr
11-02-2002 05:09 AM
Quick Reply: 1987 crx engine swap
