Proper OEM lug nut torque specs ?
Old 10-14-2003, 07:38 PM
TypeRuz's Avatar
Default Proper OEM lug nut torque specs ?
Also, it as always important to use a torque wrench for putting wheels on car?
or can i just "feel" for the proper torque?
i've heard it's bad to torque way above specs....may warp rotors. of course, below specs can be bad for obvious reasons.
Old 10-14-2003, 07:40 PM
BlueR's Avatar
Default Re: Proper OEM lug nut torque specs ? (typeruz)
80 lbs and buy a torque wrench it has other uses too
Old 10-14-2003, 07:45 PM
D
D's Avatar
about 'yay' much.
Old 10-15-2003, 04:06 PM
People_Mover's Avatar
Location: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Proper OEM lug nut torque specs ? (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">about 'yay' much.</TD></TR></TABLE>
yeah, D always uses his vocal chords as a torque wrench. click clock. lol
Old 10-16-2003, 06:41 AM
sil
sil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeruz &raquo;</TD></TR><TR><TD CLASS="quote">i've heard it's bad to torque way above specs....may warp rotors.</TD></TR></TABLE>
i've always wondered about this, but I would've thought that the warping of rotors comes from using different torque amount on all 4/5 lugs as opposed to using a number different 80ftlb.. in other words if you consistently use X ftlb on all lugs you'll be OK.. if that's the case, are torque specs given to save your threads?
Old 10-16-2003, 08:07 AM
H-T Order of Merit
nsxtasy's Avatar
Default Re: Proper OEM lug nut torque specs ? (sil)
You should always use a torque wrench.
Here is a nice one for only thirty bucks. It's money well spent.
Old 10-16-2003, 08:12 AM
jonas's Avatar
i like to use a torque wrench.. but when one is not around, just make sure they're on there pretty snug.. and of course in a star pattern.
Old 10-16-2003, 08:37 AM
D
D's Avatar
Default Re: Proper OEM lug nut torque specs ? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You should always use a torque wrench.
you sir, are a retard. many things need an appropriate bolt stretch that should be measured... ie, rod caps, main caps, tranny components... others can be rednecke'd with no issues.
D
Old 10-16-2003, 08:52 AM
Johnny Tran's Avatar
D,
whats the battle torque spec for my license plate screws?
Old 10-16-2003, 09:11 AM
AssPenny's Avatar
Default Re: Proper OEM lug nut torque specs ? (Johnny Tran)
Same as the oil drain plug
Old 10-16-2003, 09:19 AM
Default Re: Proper OEM lug nut torque specs ? (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Same as the oil drain plug </TD></TR></TABLE>
cool...so ill just put it on like the plug, with my air gun.
thanks craig
Old 10-16-2003, 09:20 AM
H-T Order of Merit
nsxtasy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You should always use a torque wrench.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">you sir, are a retard. many things need an appropriate bolt stretch that should be measured... ie, rod caps, main caps, tranny components... others can be rednecke'd with no issues.</TD></TR></TABLE>
You, sir, are very quick to throw nasty insults around without any provocation. Perhaps you are having a bad day. (Cubs fan, perhaps?)
You also ignore the fact that the question was asked about lug nuts and it would be reasonable for anyone to assume that my response should be taken within this context. However, since you are clearly more interested in attacks than in having a reasonable discussion, I will rephrase my response:
You should always use a torque wrench when tightening wheel lug nuts.
Old 10-16-2003, 10:53 AM
Alexander's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You should always use a torque wrench when tightening wheel lug nuts.
I agree.
Old 10-16-2003, 01:13 PM
Jason's Avatar
...and license plate bolts
Old 10-16-2003, 01:26 PM
Darth ModerVader
Padawan's Avatar
Default Re: Proper OEM lug nut torque specs ? (Jason)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason &raquo;</TD></TR><TR><TD CLASS="quote">
...and license plate bolts </TD></TR></TABLE>
But then sometimes they don't end up with the screw-heads vertically aligned.
Old 08-21-2009, 04:04 PM
R_ACE1's Avatar
I agree.
I second that notion.
Old 08-21-2009, 05:13 PM
safedriver's Avatar
Use the torque wrench, and avoid "breaking off" a bolt/stud. Replacing a broken bolt isn't as easy to replace on Acuras, as they are to replace on Fords, Dodges, and GM cars.
Old 08-21-2009, 10:37 PM
srt4mike's Avatar
Of course you can just guess, but it is definitely a best practice to use a torque wrench whenever possible. Guessing works fine and dandy until you mess something up.
Old 08-24-2013, 09:43 PM
HMBunch's Avatar
If you over torque the lugs you can damage the threads and risk the lugs falling off or having to cut a stud because you can't get the lug off. that is why you should use a torque wrench to tighten lugs but as long as you don't go he-man strength and just get them tight with a 4way or however you personally do it you should be good
Old 08-25-2013, 01:41 PM
mafia's Avatar
You should look at the date, this thread is from 2003.
816d16
08-15-2020 04:41 PM
93CamaroLT1
05-31-2006 06:57 PM
int3gra07
10-17-2005 09:44 AM
komat
16
06-02-2005 08:14 PM
david90
08-06-2003 03:42 AM
Quick Reply: Proper OEM lug nut torque specs ?
