help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo
Old 11-27-2002, 06:02 PM
project dc2's Avatar
Default help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo
anyways .. we had the home made turbo kit on our D16a6 motor and it ran good and finally somethign went .. we tore off the head and everything looks good .. no cracked sleeves etcc. we thought bout rebuilding it but we got a hold of a D16Z6 for a really good price. we just swapped it in today along with the home made turbo kit
14B turbo, ported turbine housing, ported HF manifold, 2 inch mandrel bent charge pipes, 2.5 inch mandrel bent downpipe, no cats, 3 inch mandrel bent exhaust, DSM 450CC injectors, filetofits chip, 1st gen DSM BOV, SS bradided oil feed line, ACT clutch, 12lb flywheel,
anways with the D16a6 it pulled like a bat out of hell
i took the D16Z6 set up aroudn the block .. around 4K it hesitates a lot it starts jerking etcc ... what coudl be wrong ?? 1st gear it would go just great .. no hesitation but any other get and itll start to bog and jerk back n forth .. and the boost goes up n down .. HLEP !
[Modified by project dc2, 3:22 AM 11/28/2002]
[Modified by project dc2, 8:54 AM 11/28/2002]
Old 11-27-2002, 08:14 PM
Drew Peacock's Avatar
Default Re: help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo (project dc2)
Perhaps its the tune the sohc vtec engines have higher compression then the D16A6, what are you using to add extra fuel..
Old 11-27-2002, 11:56 PM
Default Re: help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo (turbozxi)
bump[
Old 11-28-2002, 06:36 AM
willyboyK20's Avatar
is the vtec connected?
Old 11-28-2002, 09:37 AM
Default Re: help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo (willyboyD16)
at first we thoguht it might be the VTEC so we disconnected it .. but same **** happens i guess vtec wasnt turning on
Old 11-28-2002, 10:21 AM
G2turbo_terror's Avatar
Yikes! thats pretty much my proposed set up. I'm gonna use a wideband to check everything out once it gets put in but I'd say remove/disconect the turbo kit and get the problem solved from there. Boost just makes little problems worse.
Old 11-28-2002, 10:52 AM
civicwagonman's Avatar
Default Re: help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo (G2turbo_terror)
what are using to control your injectors? I'm running the smc. I just took off the pm6 computer and put in the p28 today. now it seems to ping sometimes above 4500. mostly in second and third gear. probably just my need 4 bigger exhaust. still don't think its pulling harder than the pm6. I had it tuned pretty well.
(remove/disconect ) ha! I thought he wrote remove/discard the turbo at first! pays to read stuff twice sometimes.
Old 11-28-2002, 11:03 AM
GraphiteAccord's Avatar
Default Re: help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo (civicwagonman)
sounds like its running lean. need to add in some fuel..this is where the v-afc hack is better then the smc...you can ad fuel % at different rpms.
Old 11-28-2002, 02:34 PM
mstsh80's Avatar
my turbo h22 did this till i found the vaccum line ti the fpr was kinked. i re did all my lines and now the car has power and boost all the way to 7400. it pulls like a mo fo now
Old 11-28-2002, 03:42 PM
Default Re: help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo (spoolin22)
bump
Old 11-28-2002, 03:55 PM
what computer and setup are you running with the d16z6?
Old 11-28-2002, 06:05 PM
pm6, filetofit chip for the 450s, and summit racing RPM switch
Old 11-28-2002, 07:20 PM
bump!
Old 11-29-2002, 12:17 PM
bump boing
[Modified by project dc2, 11:45 PM 11/29/2002]
Old 11-29-2002, 05:51 PM
update----
installed a NOS in-line fuel pump today, still bogging at 4K RPM etcc, when the mtoor is cold it runs fine, pretty smooth actually, im throwing a code 20 ( electronic overload or somethign), and a code 17 ( VSS-vehicle speed sensor) i thought the 89 civic si uses a cable speedo ?? how can we have this problem ? well anyways, GIVE ME SOME FEEDBACK PEOPLE.... please i need to get this car up n runnin, its gettin on my nerves imma set it on fire
and the starter wont work and im guessin the altenators busted but imma check to see how many volts it pushes out..... soo replY !
Old 11-30-2002, 10:00 AM
bump
Old 11-30-2002, 11:06 AM
bump !
Old 11-30-2002, 11:23 AM
the computer reads from the back of your speedo for the vss. check your connections and reset your codes. might possibly have a bad speedo also.
Old 11-30-2002, 04:53 PM
boing
Old 11-30-2002, 05:34 PM
rjardy's Avatar
is the map limiter that you got from filetofit wired in corectly?
Rob
Old 11-30-2002, 05:41 PM
Default Re: help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo (rjardy)
yea its wired correctly
Miramax
09-16-2015 01:26 AM
I CRX I
10-05-2010 07:42 PM
ConfusedEGCoupe
11-04-2008 06:45 PM
jdmdseries
11-26-2007 07:28 PM
Gold DA9
Northeast (Sales)
05-20-2007 07:39 PM
Quick Reply: help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo
