how to install RED H emblem
Re: (c_mack9)
peel them off, then use WD40 to remove the adhesive. you can use WD40 and dental floss to get them off, too. works a little better than just peeling. make sure it's the waxed dental floss, though.
Re: how to install FIT type r emblem (jdmda7)
use a heat gun to heat up the emblem and then peel it off i used a credit card for mine but a heat gun is better...
Re: how to install FIT type r emblem (JRRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRRR »</TD></TR><TR><TD CLASS="quote">use a heat gun to heat up the emblem and then peel it off i used a credit card for mine but a heat gun is better...</TD></TR></TABLE>
I used a credit card and it worked for me.
Re: how to install FIT type r emblem (eL)
Sorry EL but he really should learn to search https://honda-tech.com/zerothread?id=1920787
Re: how to install FIT type r emblem (fitfreak3)
why would you use a heat gun on the stock emblems? theres no adhesive holding the stock H badges to the fit...
for the back look up behind the rear hatch handle on the outside and you'll see 2 tabs sticking in from the outside, break them off and the emblem comes off very easily
the front use a credit card and pry it out, the credit card won't harm the black grill material
Re: how to install FIT type r emblem (yeamans17)
yeah well i used a heat gun to take the type r ones off, becuase there is no type r fit so i just put the stock ones back on cause i painted them black...they look pretty hard...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeamans17 »</TD></TR><TR><TD CLASS="quote">why would you use a heat gun on the stock emblems? theres no adhesive holding the stock H badges to the fit...
I think he was referring to the FIT emblem and not the H emblem.
LOWLIFEHATCH
02-17-2003 12:02 PM
