How to remove Rear engine mount?
Old 12-29-2006, 04:52 PM
Sweetsystem's Avatar
Default How to remove Rear engine mount?
Guys I need some detailed info on how to remove the rear engine mount. I searched and everyone is vague. Do I have to remove my intake Manifold? Power steering rack?
Ultimately im trying to remove the engine. got everything else off except the mounts and intake mani.
Thanks
Old 12-29-2006, 04:56 PM
Fat Chick Magnet's Avatar
good luck. its a bitch to take it out.......took 3 guys to take my rear mount out and replace it with innovative. one guy jacking the motor up another guy watching from the top removing the bolt and another guy under the car trying to pull the mount out.
oh and it was our first time.
Old 12-29-2006, 05:15 PM
* B A N N E D *
GRAF-FITI's Avatar
Default Re: (dc2rtek)
removing the intake maifold is the easiest way to go about it, then the mounting bracket for the motor mount, then the mount itself
here's a good write up on it: http://www.team-integra.net/fo...age=2
Old 12-29-2006, 05:16 PM
i just took my intake off and it was easy to get to it.
Old 12-29-2006, 05:25 PM
jdm_bones's Avatar
Default Re: How to remove Rear engine mount? (Sweetsystem)
Put your car on jack stands, come from under the car and hit with an impact gun. Make sure that you have a jack at the tranny ever so slightly pushing up on it and make sure that the crane is well attached to the engine...
Old 12-30-2006, 03:16 AM
dc4teggiehatch's Avatar
took off tranny mount and left torque mount, loosend rear moutn bracket as well, jack stands on car and jack under motor, slowly raised/dropped til had enuff room (play) to wiggle out the rear mount. the hardest part is putting the bolts back in tight. you need alot of tools.
Old 12-30-2006, 05:57 AM
qfast817's Avatar
Default Re: (96teggiehatch)
its easyer when you remove the breather box, take out the rear l bracket
Old 12-30-2006, 08:25 AM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggiehatch &raquo;</TD></TR><TR><TD CLASS="quote">took off tranny mount and left torque mount, loosend rear moutn bracket as well, jack stands on car and jack under motor, slowly raised/dropped til had enuff room (play) to wiggle out the rear mount. the hardest part is putting the bolts back in tight. you need alot of tools.</TD></TR></TABLE>
x2
Ali
Old 01-02-2007, 12:13 PM
Thanks Guys. Completed all Maint. T Belt, Clutch, Tranny Fluid, Axles, front torque mounts, polyurethane engine mount inserts, All belts and hoses, Valve cover gasket, and Cam plug. Runs like brand new!
Side note: The Urethane inserts really firm up the engine, almost too much for my comfort level. I might be taking the two front ones out and just keeping the rear one in.
98bucket
03-01-2011 08:41 AM
acmoc
11-25-2008 10:03 AM
the.hamburglar
07-21-2005 02:47 PM
SurferX
03-03-2003 02:16 PM
Quick Reply: How to remove Rear engine mount?
