Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..?
Old 08-30-2006, 11:06 AM
4gencivicef9's Avatar
Default Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..?
anyone had this I just did a b16a swap into a 89 dx 1.5 I was thinking maybe it might be a lean condition and I am going to swap out the fuel pump also I am going to change ecu cause I have a pr3 ecu that is automatic?
Just figured I post up and see if anyone has had this prob..?
Old 08-30-2006, 11:49 AM
Maldito X's Avatar
Default Re: Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..? (4
I have the same problem, but its on my d16a6, and I'm pretty sure its my ignitor in my distributor. Other problems could be a filter and or dirty injectors. Though I'm almost certain its ignitor that's bad.
Autozone can run diagnostic check on your ignitor and tell you if its bad, I think. But I am not certain, since its a pr3, and idk what dizzy you are running. I don't know if that would be a problem.
Old 08-30-2006, 12:18 PM
yea I am obd0 I think it is td-22 or td-44 it's obd0, but thanks I am going to try to take to autoparts place and get it tested I dont think they do that around my way though..?
Old 08-30-2006, 12:22 PM
I cleaned out my injectors and put new seals and still the same they are working though is there away to test them..? or tell? I think it is between the fpump and ecu though..
Old 08-30-2006, 01:09 PM
Maldito X's Avatar
Yeah, I suspect its a problem with your dizzy,like the ignitor, I don't know what replacement there is for an obd 0 dizzy on ur b16, I'm not sure if you can mix and match, but why not go and find an obd0 ignitor off a b18 integra. Checker, kragen, autozone might run a check on ur ignitor, autozone offered to diagnose mine before buying. Is your tach needle bouncing around?
The Punk has me set on 10 posts a day limit, so if I have more to say, I will edit this post. Therefore read back on here to see if I respond, instead of checking for a new post from me.
Old 08-30-2006, 02:30 PM
eudm_eg8's Avatar
i had the same problem on my d15b2 - when i pressed on gas pedal it bogged, if i floored it, it bogged like crazy.then one day my car wouldn't start up - there was no spark.my mechanic changed the ignition coil and now it works like new.
Old 08-30-2006, 03:55 PM
saikouEF8's Avatar
check your thermostat ground wire. if not that then check coil and igniter
Old 08-30-2006, 05:47 PM
CASTUDILLO01's Avatar
MAKE SURE YOU SWAP THE YELLOW/WHITE AND GREEN/WHITE WIRE ON THE TPS SENSOR THEY READ BACKWARDS IN A DUAL POINT SYSTEM THEN ON A MILTIPORT. FOUND THAT TO BE VERY COMMON ON SWAPS PEOPLE DID AND FORGOT TO SWAP THOSE WIRES AROUND. ALSO USE A JUMPER HARNESS ON THE DISTRIBUTOR BETTER THEN SWAPPING WIRES AROUND AND HAVE TO RUN WIRES TO THE ECU.
Old 08-30-2006, 06:35 PM
I am going to check the ignition coil to double check..
Old 08-30-2006, 06:37 PM
? I dont understand the car will bog if the tps is backwards, yel/white , gre/white. on the ecu?
Old 08-30-2006, 06:50 PM
Mr. Giggles's Avatar
a wire on my map sensor was disconnected.. backfired and bogged like a bitch.
Old 08-30-2006, 08:05 PM
mahatma's Avatar
cam timing a tooth or 2 off?
Old 08-30-2006, 08:09 PM
SVOboy's Avatar
He was saying that if you didn't switch the tps wires when you did the MPFI wiring it will cause such things, I'm with him for now.
slimshady101
03-02-2012 01:32 PM
88SeeOurEx
09-10-2009 05:36 PM
92integracer
10-07-2008 07:05 PM
90jdmcrxdude
05-05-2006 10:20 PM
poundedhatchcrap
10-27-2005 06:31 AM
Quick Reply: Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..?
