Headlight reminder beeper
Old 05-16-2005, 12:20 PM
bdptcob's Avatar
Default Headlight reminder beeper
I have a 2002 Civic. Not too long ago the headlight reminder beeper stopped working. My wife for whatever reason cannot remember to turn them off and it almost resulted in a dead batter 300mi away from home. I assumed it was a fuse. I checked the user manual (and did a search on the forums) but did not see any fuse slot title anything remotely close to beeper or reminder. I could check every fuse, time consuming as it may be, but I wanted to ask here first. Anyone else experience anything along these lines? Thanks.
Old 05-16-2005, 12:22 PM
Cypher0117's Avatar
Default Re: Headlight reminder beeper (bdptcob)
i have a similar concern unless a 94 civic dx doesn't come w/ a headlight beeper
Old 05-16-2005, 01:16 PM
longbeachpurplecivic's Avatar
Default Re: Headlight reminder beeper (Cypher0117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cypher0117 &raquo;</TD></TR><TR><TD CLASS="quote">i have a similar concern unless a 94 civic dx doesn't come w/ a headlight beeper</TD></TR></TABLE>
never came with it, 96 up civics do
Old 05-16-2005, 01:30 PM
BS 22's Avatar
Default Re: Headlight reminder beeper (longbeachpurplecivic)
I've left my headlights on twice, both times the battery died just because I don't have that reminder thing. Oh well, doesn't happen to me anymore.
Old 05-16-2005, 01:35 PM
Methuselah's Avatar
it's an easy add-on... go to radio-shack and get a simple 12 volt beeper and wire one end to the parking-lights (+12 when lights are on) and the other to the dome-light switch for the door (grounds when the door opens).
When the door opens and the lights are on, it beeps.
good luck.
Old 05-16-2005, 01:49 PM
IHateJDM's Avatar
Default Re: Headlight reminder beeper (BS 22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BS 22 &raquo;</TD></TR><TR><TD CLASS="quote">I've left my headlights on twice, both times the battery died just because I don't have that reminder thing.</TD></TR></TABLE>
I've done that so many times, lol. damn 93. at least its a honda, anything heavier and you can't push it off by yourself.
Old 05-16-2005, 01:52 PM
Electrician
Deemeetree's Avatar
Default Re: Headlight reminder beeper (Methuselah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Methuselah &raquo;</TD></TR><TR><TD CLASS="quote">it's an easy add-on... go to radio-shack and get a simple 12 volt beeper and wire one end to the parking-lights (+12 when lights are on) and the other to the dome-light switch for the door (grounds when the door opens).
good luck.</TD></TR></TABLE>
This sounds like a good way, but he already has one factory installed.
You'll need to troubleshoot it on why it doens't beep. Make sure the fuse for it is in good condition. Make sure none of the wires that goes to the doors fell off (the one that are in the door jamb to trigger the interior lights or beeper).
Old 05-16-2005, 02:03 PM
civiccoupe94's Avatar
Default Re: Headlight reminder beeper (Dimitri_EG8)
wheres the dome light switch wire? and how much is the beeper at radio shack?
Old 05-16-2005, 02:50 PM
Bcuz's Avatar
Your problem is caused by the recall on your vehicle, take your car into a honda dealership. They will replace your switch which is probably burnt by now. It's called the "combo light switch recall", they'll know what you mean. Good Luck.
Old 05-16-2005, 07:38 PM
bdptcob's Avatar
Default Re: Headlight reminder beeper (Bcuz)
Thank you very, very much.
Old 05-16-2005, 07:43 PM
BS 22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz &raquo;</TD></TR><TR><TD CLASS="quote">Your problem is caused by the recall on your vehicle, take your car into a honda dealership. They will replace your switch which is probably burnt by now. It's called the "combo light switch recall", they'll know what you mean. Good Luck. </TD></TR></TABLE>
Badass!
Thanks for the answers guys
&lt;--- taking it to honda this weekend
Old 07-08-2006, 11:16 AM
BoBakTXL's Avatar
the beeper you can buy from walmart...
does it have 2 positives and one ground?
1 goes to the headlight...
1 to the ignition (or windshield wiper)...
and one to the ground?
Old 07-08-2006, 01:32 PM
commotion's Avatar
Default Re: Headlight reminder beeper (BoBakTXL)
i have a 1995 civic and mine beeps
Old 07-08-2006, 08:11 PM
AIRIC's Avatar
Default Re: Headlight reminder beeper (commotion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commotion &raquo;</TD></TR><TR><TD CLASS="quote">i have a 1995 civic and mine beeps</TD></TR></TABLE>
i have a 93 civic and mine beeps when the door is open and the keys are in the ignition
vivithemage
04-12-2007 08:10 PM
asubennett
08-27-2004 10:13 AM
Buddhastic
06-08-2004 02:21 PM
dowhatyouwant
09-23-2003 09:47 PM
Charlie Moua
17
04-11-2003 04:26 AM
Quick Reply: Headlight reminder beeper
