Very fine red/rustish looking dust inside distributor cap???
Old 04-23-2005, 01:35 PM
IloveNewt's Avatar
Default Very fine red/rustish looking dust inside distributor cap???
As the subject states, there is this very fine redish/rustish looking dust covering the inside of my cap. Is this OK? Normal? Anyone else have this? My ignition setup is stock except for a msd blaster coil.
Old 04-23-2005, 03:37 PM
non-VTEC's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (MordecaiPSI)
i do belive that redish dust/rust is coming from your distributor bearing. its on it's way out......you should be replacing it soon. $$$
Old 04-23-2005, 04:03 PM
BlueSi2k's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (non-VTEC)
you may be gettin some moisture inside the cap. How did you run the wires from the external coil? Have you washed under your hood lately?
Old 04-23-2005, 08:14 PM
IloveNewt's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (BlueSi2k)
I am not sure what you mean by running the wires from my external coil. You know the H23 came with an external coil stock correct?
Are you sure this is a sign of the distributor going out? Dont dizzies make weird knocking sounds when they start going bad?
Old 04-23-2005, 08:48 PM
EE_Chris's Avatar
They nicknamed it "Red Death" for a reason - your distributor bushing is about to go. You have to replace the sub-assembly.
Old 04-23-2005, 08:58 PM
FredoSP's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (EE_Chris)
what exactly is the distributor bushing?
Old 04-24-2005, 01:38 AM
havok hybrid's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (FredoSP)
IF you happen you be running a MSD cap .. the red dust is from the glue/filling its breaking down.....
Or its the bushing it you have stock cap.. or both
Old 04-24-2005, 05:01 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">what exactly is the distributor bushing?</TD></TR></TABLE>
Its what the distributor shaft spins on.
Old 04-24-2005, 07:50 AM
mrDFWmechanic's Avatar
so when u see this " red death " you have to replace the whole dizzy then
Old 04-24-2005, 08:25 AM
IloveNewt's Avatar
Default Re: (iROCKtheSOHC)
Damnit.......this distruibutor is less than 5,000 miles old. Anyone know where to get a new OEM dizzy thats not an arm and a leg?
Old 04-24-2005, 04:17 PM
BlueSi2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MordecaiPSI &raquo;</TD></TR><TR><TD CLASS="quote">I am not sure what you mean by running the wires from my external coil. You know the H23 came with an external coil stock correct?
Are you sure this is a sign of the distributor going out? Dont dizzies make weird knocking sounds when they start going bad?</TD></TR></TABLE>
Oh, my bad. On b series you have to run the wires out from the internal coil.
ek9_B18C
04-05-2015 04:43 AM
joncowden
03-11-2008 06:14 AM
dyg2001
02-24-2004 09:38 AM
ernald711
08-19-2003 12:31 AM
FastNFurious
06-19-2003 09:14 PM
Quick Reply: Very fine red/rustish looking dust inside distributor cap???
