gear ratios - d16z6 vs d16y8
Old 04-03-2002, 01:25 PM
willyboyK20's Avatar
Default gear ratios - d16z6 vs d16y8
i just wanted to know are the they different or the same.
ps: I heard from someone that the Z6 tranny is a little bit stronger is this true or not
thanks
Old 12-23-2002, 03:23 PM
thisisntjared's Avatar
Default Re: gear ratios - d16z6 vs d16y8 (willyboyD16)
old post but same unanswered question.
Old 12-23-2002, 03:48 PM
tbisme's Avatar
I have a d16z6 in my si and was wondering how mutch the tranny would take. Are the raitos the same? I put 17" weeles on mine and it slowed it down...... 1/8 mi track. I would like to find a bolt-in tranny with some beef that would give my final Back. what about you,
Old 12-23-2002, 03:49 PM
Default Re: gear ratios - d16z6 vs d16y8 (tbisme)
im replacing my z6 tranny with a y8 tranny and wanted to know all the differences.
Old 12-23-2002, 04:03 PM
tbisme's Avatar
Default Re: gear ratios - d16z6 vs d16y8 (bleh)
What is the reason for the change did your z6 not hold up?
Old 12-23-2002, 04:41 PM
na i bought the car with a auto to manual swap and the wrong tranny mounts were used. after the axle popped out a few times and screwed things up and got replaced (the axle was replaced twice so far) the right mount was put in and the problem still persisted. my mechanic said i would be best off getting a new tranny.
[Modified by bleh, 8:52 PM 12/23/2002]
Old 12-23-2002, 08:22 PM
anyone know the ratios for a 2000 ex tranny?
Old 12-23-2002, 11:58 PM
kinesistech's Avatar
The ratios are the same. The y8 is stronger because the shift forks in the z6's are cast aluminum and may break in the middle of your 1-2 shift at the race track and cause you to run a 30sec quarter. The y8 uses steel shift forks. There are other minor differences between the 2 so the better shift forks dont fit the older trannys. The shortest geared d-series tranny I found is the del sol si tranny. My old one used to wind out faster than my current z6.
Old 12-24-2002, 02:46 AM
D Tranny Guru
Mista Bone's Avatar
D series tranny god here.............
Only difference gearing wise is 5th gear.
92-95 Civic Si and Sol Si got .750 5th, everything else got .702 5th gear.
Check the link in my sig.......
Xxcivic97xX
11
02-17-2017 05:40 PM
Tom123456
07-28-2006 12:32 AM
gulftools
03-30-2003 09:50 AM
ryu12341
06-22-2002 11:32 AM
therealnapster
03-26-2002 06:19 AM
Quick Reply: gear ratios - d16z6 vs d16y8
