Broken camshaft?
Old 10-23-2004, 03:17 PM
DiGG3r's Avatar
Default Broken camshaft?
I was driving and the motor just quit (0 RPM), when I tried to restart, the car turned but wouldn't start. I went through the usual checking to see what happened (fuel pump & line, timing belt, fuses, dizzy, etc.) The timing belt was fine, but the dizzy wasn't turning, I guessed it was bad. Then I took off the valve cover to see if it was anything else, When I had the car try to start I looked at the camshaft, it was only turning over cylinder 1, not anywhere else. I have a stock 94 accord 2.2L, with no mods. Does this mean my camshaft broke?? Please HELP!
Old 10-23-2004, 04:35 PM
StimpyBoy's Avatar
Default Re: Broken camshaft? (DiGG3r)
From what you've described, you pretty much nailed your own problem. You had someone else try to start the engine while you watched, right?
I've never heard of a camshaft snapping like that in a stock Accord engine, but I guess there's a first time for everything
BTW, if you did get it right, then you probably have valve/piston damage as well as I'm sure you're aware. If you're sure it's the camshaft, you're going to have to pull the head now and look for damage for sure. Sorry.
Old 10-23-2004, 04:40 PM
Section.9.Auto's Avatar
Default Re: Broken camshaft? (StimpyBoy)
It can happen i have seen it a few times on hondas. Usually only on the older ones like mid 80s. When they go it usually destroys the whole head, because the cam bents the line bore that the shaft runs down. Can be re-machined , but cheaper to get a whole reman head and put it on. That also gets rid of the valves that are most likely bent.
Old 10-23-2004, 05:40 PM
DiGG3r's Avatar
Default Re: Broken camshaft? (Section.9.Auto)
So do I have to remachine my head? What would cause the cam to break like that to begin with? It's all stock and I don't race, so what would cause the cam to break like that??
Old 10-23-2004, 05:45 PM
bill-71SS's Avatar
I have seen that happen a lot when there was an oil problem and the cam seizes in the head and snaps.
Old 10-23-2004, 06:17 PM
DiGG3r's Avatar
Default Re: Broken camshaft? (bill-71SS)
well my oil light did come on about a day or two before the cam broke, I checked my oil and it was full. This repair is going to cost me quite a bit.
Old 10-23-2004, 07:14 PM
New User
Nick H's Avatar
you most likely had an oil passage clogged, or something along those lines...if your cam broke, then you may be dealing with more than just machining...you most likely will need a new head, or remachined head, along with most other parts of your valve train...they go on ebay for cheap though...other causes of cams breaking are hitting the rev limiter or over revving the engine to where the cam was spinning too fast for its own strength...can you physically see a break/crack in the cam? is the entire thing spinning?
Old 10-23-2004, 07:26 PM
DiGG3r's Avatar
Default Re: Broken camshaft? (Nick H)
The cam only spins up to the first cam holder (which I'm guessing where the break is, and I can't see the actual break), the rest of the cam doesn't move at all.
BTW, thanks for all the advice from those who responded.
Old 10-23-2004, 07:36 PM
Shinbo's Avatar
I think this is a glorious opportunity for a new car
therest
03-09-2016 07:19 AM
mattbandelt
12-17-2012 08:49 AM
asondemitri
01-16-2012 04:47 PM
MakinAComeBack
Classic Hondas
04-26-2008 06:57 AM
casp
09-07-2005 09:09 PM
Quick Reply: Broken camshaft?
