widest rim to run on ek?
Old 11-28-2006, 08:36 PM
jiggatone's Avatar
Default widest rim to run on ek?
well yeah im jus wondering whats the widest with the lowest offset i can go on a 96 ek hatch.cuz damn ive been see'in these cars with crazy offset majority of em from "Phaze 2" and yeah.whats the max i can run without rolling fenders or rubbing?cars like these on HT i kind of wanna do the same thing.im on stock shocks and skunk2 coilovers.also does anyone know these guys wheel specs?i dont remember whos cars these are but i did get them from here.
Old 11-28-2006, 09:28 PM
H-T Order of Merit
nsxtasy's Avatar
Default Re: widest rim to run on ek? (tonEK)
I'll assume this is for street tires, not for track tires.
Don't start out with step 5. You need to make your decisions in this order:
1. Decide on what diameter wheel to get (15", 16", etc).
2. Find out what the best tire size is for that size rim on your '96 Hatchback, which is:
15" rims - 195/50-15
16" rims - 205/40-16
3. Decide on what kind of tires you want to get.
4. Look up what rim widths are approved for the tire and size you're getting.
Most 195/50-15 tires are approved for rims 5.5-7.0 inches wide, and I recommend 15x6.
Most 205/40-16 tires are approved for rims 7.0-8.0 inches wide, and I recommend 16x7.
5. Decide what rim width to get, based on what's approved for your tires and what's available for the rims you like.
Old 11-28-2006, 09:35 PM
r.wright's Avatar
Default Re: widest rim to run on ek? (nsxtasy)
the pics of the cars up above are using negative camber ,stretched tires and have rolled fenders. i would look into a better coilover and/or strut setup(more stiff) if you wanna avoid harsh rubbing
Old 11-29-2006, 03:06 PM
dvp
dvp's Avatar
Default Re: widest rim to run on ek? (mrrlx)
The tire is the limiting factor on most Hondas. The widest tire that will fit being as close to possible with the stock OD is a 225 45 15. And with that you wont need a wheel any wider than an 8". Let alone the fact you won't be able to fit it without flaring the fenders and then you'll have to get an oversized tire to fit the rim....ugh.
Old 12-05-2006, 07:22 PM
integraboi2626's Avatar
Default Re: widest rim to run on ek? (dvp)
what kind of rims are those?
Old 12-05-2006, 09:03 PM
Wendys or Bust's Avatar
yup, I was wondering the same thing. If I cant find a good 20-30 offset wheel, I'll be picking up a set of 16x7 +33 FN01R-C's. I'll mount them on a 205/45 Spt and see how they sit. I want my wheels sticking 3-5mm out from the fender. I'll get longer arp studs and a spacer if I need to.
And I want to roll my fenders a bit too, I've always really liked wide low stances.
Old 12-05-2006, 11:06 PM
vtecsi00's Avatar
Default Re: (Wendys or Bust)
i believe they are running a 15x8 with a 20mm offset with rolled fenders...but can't think of what wheels they are...there was a thread of someone selling that type of whel i believe
Old 12-06-2006, 06:24 AM
Default Re: (vtecsi00)
oh. you are thinking about another wheel. You are thinking about https://honda-tech.com/zerothread?id=1802720
Old 12-12-2006, 08:12 AM
Hazesus's Avatar
https://honda-tech.com/zerothread?id=1789832&page=1
Old 12-12-2006, 03:55 PM
kangaroo's Avatar
I also like the looks of the wide wheels with the deeper lips.
Question about rolled fender.
Can you keep the plastic wheel well cover under the fender???
or
When you roll you fender you can't have that plastic peice anymore.
Because that plastic peice is connected to the outer part of the fender that you will roll.
I was going to roll my fender but didn't want to lose that plastic peice because then I would get dirt and crap all under my hood.
Old 12-12-2006, 04:21 PM
H-T Order of Merit
nsxtasy's Avatar
Default Re: (kangaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kangaroo &raquo;</TD></TR><TR><TD CLASS="quote">I was going to roll my fender but didn't want to lose that plastic peice because then I would get dirt and crap all under my hood.</TD></TR></TABLE>
The bigger problem with losing the fender liners is that they protect the inside of the fenders from gravel and other objects kicked up by the tires. Without them, the fenders can easily get "dinged" (dented) from underneath.
Old 12-12-2006, 04:42 PM
kangaroo's Avatar
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
So I can't roll my fender without losing the fender liner??
ProZack
02-03-2012 10:15 PM
NorthVVestHD
12-20-2011 07:27 AM
760ek9
06-15-2009 04:47 PM
4th-gen-civic
05-18-2007 02:25 PM
Quick Reply: widest rim to run on ek?
