How to paint chrome rims
Old 02-11-2009, 06:38 PM
tpot90's Avatar
Default How to paint chrome rims
I want to paint my rims black. The problem is that they're chrome (or chrome dipped?). My question is How do I get rid of the chrome so I can begin the painting process? I am just assuming I need to remove the chrome for the paint to bond, someone let me know if there is an easier way of doing this. Would the AIRCRAFT remover take off chrome?
I've googled this a million times but cant find any solid information.
Any assistance is appreciated. Thanks guys
Old 02-11-2009, 06:55 PM
r.wright's Avatar
Default Re: How to paint chrome rims
no it wont remove it..
chrome plate needs to be acid dipped or sometimes sandblasted to be removed properly.
i remember long time ago i had some rims that were chrome and all i did was scuff them down a lil bit and the duplicolor paint stuck on there pretty good. and this was about 5 yrs ago and the og owner still has the original coat on there..
i guess if the wheel does not have any crazy pitting spots or dips then go for it. but if it does these spots will show under the paints layer.
Old 02-11-2009, 07:39 PM
Sanji
toyomatt84's Avatar
In order to get the "chrome" plating completely off, you have to take off the primary layer of Nickel. You'll need to either media blast them with some harsher grade media (could destroy the wheel), or get busy with the sandpaper.
Old 02-12-2009, 01:06 PM
tpot90's Avatar
Can I use a Hi-grit sand paper and put it on a drill disk to sand them down? If so, I need to know the best grit paper for this project. And who else has done this? Anybody with experienced suggestions?
Old 02-12-2009, 03:39 PM
Sanji
toyomatt84's Avatar
https://honda-tech.com/forums/showpo...&postcount=347
Old 02-13-2009, 02:28 PM
tpot90's Avatar
What is glassbead blasting? Is it something I can do from home??
Old 02-13-2009, 02:38 PM
Sanji
toyomatt84's Avatar
It's the same as sandblasting, just with different media (glass beads instead of sand, as they're far less abrasive). You can do it at home, if you rent/buy a blaster, buy some glass bead media, and have a decent air compressor.
send2artem
10-15-2010 06:23 AM
J_CRX
03-02-2008 12:42 AM
aznxguyx89
08-30-2007 08:49 PM
melvin
10-27-2005 07:40 PM
PoWeRBaN_PaNdA
04-30-2002 11:01 PM
Quick Reply: How to paint chrome rims
