Tube Chassis, front end? Tubular front?
#27
Re: Tube Chassis, front end? Tubular front?
I would assume the more tire on the ground the better for a striaghtline type event. You also have to take into account how the car will track/steer so it wont dart around as well. But you are right about the camber,ect although I am not super sure about how beneficial.
#28
#30
haha point taken Im hoping that I can combine my engineering degree with some common sense to avoid some of these problems us engineers are plagued with.
#31
Don't get me wrong, I not only respect what ya'll do, I have a passion for it. As I have taken everything except one english class for my 2 year transfer. I just found that I'd rather build stuff than engineer it. Now I use a combination of both skills to do custom stuff. I would like to get further into engineering as math is another passion of mine. but i tend to over complicate things a bit much to BE an engineer
#32
dont know how much this helps but i cut the front off right before the engine mounts and cut plates and welded them on the ends of the frames. then i built a hoop straight out the front, down bars from the upper fender supports (not sure what they are called) and then did a downward hoop for front engine mouning, rad support, etc........
mike
mike
#37
that is some really bad A$$ stuff guys... I'll get some more pics of my latest work. it's nothin as extreme as ya'll but I take pride in the quality and appearance of my small custom add-on's.
#42
i would like to get more info from you on the crx set up. Im having issues witht the rear xmemeber bending. I see you tube the front end and made a motor plate. Do you have more pictures of this. Cant wait to hear back from you.
