Transmission & Drivetrain Gearboxes, Differentials, Clutches
M2B4, T2T4, difference?
Old 03-20-2015, 03:28 PM
Tachi's Avatar
Default M2B4, T2T4, difference?
(I tried google and that yielded nothing substantial)
They have the same gear ratios from what I can tell, they both have a LSD. I'm getting ready to buy one to put in my Accord (bought with a H22, synchros are failing) and just want to know if there is any substantial difference to keep an eye out for, or if it is purely because one trans went into a Prelude and the other went into an Accord?
Thank you for the time.
Old 03-21-2015, 06:05 AM
B18c-R_ej6's Avatar
Default Re: M2B4, T2T4, difference?
M2B4-
1- 3.307
2- 1.95
3- 1.36
4- 1.034
5- 0.787
fd- 4.266
lsd- Y
T2T4-
1- 3.285
2- 1.956
3- 1.344
4- 1.034
5- 0.787
fd- 4.266
lsd- Y
Old 03-21-2015, 09:02 AM
CD8
CD8's Avatar
I want to see your newly aquired accord, or where ur from? Im trying to track down my project which i regret selling...
Old 03-21-2015, 04:49 PM
ESP.net's Avatar
From I know 3rd gear lil shorter with T2T4 that is bout it.
However the cases are different. M2B4 is all by its self on Clutch Housing and case. T2T4 I believe you may be able to put in an aftermarket diff in it. M2B4. I don't think there is an option and is all by itself once again. Synchros should be similar if not same...
Old 03-21-2015, 07:04 PM
Tachi's Avatar
I haven't been able to find any forum posts or definitive answer on what Honda's factory limited-slips were, I'm hoping torsen but I suspect viscous? Somehow viscous-couplings seem a bit low-brow for the "red H".
Different cases? Will is still transplant into a CD5/H22A? Is the starter unique to the transmission? My goal is to be able to still use Accord/Prelude maintenance items like the starter or synchro rings/bearings. If the diff is something other than viscous then it will be fine, this will be mostly for DD/autocross with a little drag racing.
CD8, I'll make a post in the Accord picture thread, I was waiting until I cleaned the wheels to take photos.
TurboDlude
01-28-2007 01:43 PM
Quick Reply: M2B4, T2T4, difference?
