k24a2 axles
k24a2 axles
I'm nearing the completion of all of the parts required to swap a k24a2 engine and trans into my eg civic , I have looked every where on the internet regarding the answer to my question. Is there any way I can use the stock k24 tsx axles that I have by swapping to b series outer joints and swapping inner joints rom side to side, Or do I have to use base rsx axles and do the inner joint swap? I have measured the k24 axles in relation to the rsx axles without swapping any joints and the tsx axles are shorter on one side and longer on the other than the rsx, Hopefully some one can help me.
D Tranny Guru
Re: k24a2 axles
Sell swap and by a brokedick D Series
Why swap the ends of the axles when you can just buy new hubs to fit the larger outers, good time to install new wheel bearings and such.
JDMotive
08-04-2004 08:54 AM
