Carbon Synchro question
Hey guys,
Recently my b16 box started to get jammed in reverse, after doing a bit of searching ive found its possibly the 5-R syncro set so im going to order one. Now im just wondering, will I have any problems going to a carbon lined syncro over brass if im retaining all other oem syncros? The box feels perfect and has no grinds, just the jamming reverse.
Thanks guys
Thanks guys
Re: Carbon Synchro question
Shouldn't have any issue with the carbon-lined synchro really. The jamming in reverse could likely be worn 5th gear sleeve teeth though. You'll probably need the 5/R sleeve.
and yep the whole set was the plan, worded it wrong, sleeve, synchro and spring set like below.
magefa
Transmission & Drivetrain
11-21-2008 09:29 PM
MOVE OVER
07-19-2007 05:19 AM
