Transmission & Drivetrain Gearboxes, Differentials, Clutches
B18 cable trans with hydro LS gear set, ITR LSD, 4.9FD. - what gears are compatible?
Old 03-01-2017, 03:59 PM
Black R's Avatar
Default B18 cable trans with hydro LS gear set, ITR LSD, 4.9FD. - what gears are compatible?
Hi, I have this:
what gears are compatible or a decent upgrade?
i happen to have usdm itr 1,3,4,5 gears sitting collecting dust somewhere in my garage.
Old 03-03-2017, 03:55 PM
Aquafina's Avatar
Default Re: B18 cable trans with hydro LS gear set, ITR LSD, 4.9FD. - what gears are compatib
If you want to use the ITR 3/4 gears you'll need the larger BVTEC synchros, hub, slider and shift fork.
Old 03-03-2017, 10:35 PM
JRCivic1's Avatar
Have you considered running the stock 1-4 LS gears with the 4.92 final drive and simply replace 5th with a B16/ITR gear pair ??? This is what I am going to do with my road race Teg... I bet Aquafina might even give his seal of approval on this combination for a moderate powered road race or autocross car.
Old 03-06-2017, 06:29 AM
Black R's Avatar
This is a spare (autox / street) tranny that I have.
My other tranny in the "racecar" is hydro with an itr 2nd gear and ATS 1/3/4/5 gears, ATS 4.9 final and ATS metal LSD.
For most courses, I only use 2nd and 3rd gear.
I also have have a spare ATS first gear - but it's for a tranny with a 4.4 final drive, so I'm not sure if it would be compatible with my LS cable tranny.
​​​​​​​i think at some point (not in the near future) I'd like to try a tranny that runs up to about 78mph in 2nd gear - that would be ideal IMO.
Old 03-09-2017, 09:11 AM
Aquafina's Avatar
For street cars I don't mind the LS gears and a shorter FD, but I don't like them for most tracks. Autocross could be ok depending on the course layout and power output.
CRXTHIS
12-07-2006 01:51 PM
GR_DC2
10-02-2005 04:38 PM
Em0ne
08-16-2004 05:41 PM
P73 DA9
03-20-2002 03:49 PM
P73 DA9
03-19-2002 10:26 AM
Quick Reply: B18 cable trans with hydro LS gear set, ITR LSD, 4.9FD. - what gears are compatible?
