Transmission & Drivetrain Gearboxes, Differentials, Clutches
87 HF Trans Swap Into 88 Sedan Questions
Old 01-29-2017, 04:36 PM
scottiefenton90's Avatar
Default 87 HF Trans Swap Into 88 Sedan Questions
Hello, this is my first post on this forum
I'm very interested in swapping an 87 HF Trans in and pulling the SI trans,
Question is what differences will I run into, splines, axles, clutch, flywheel, ect..
I've done research saying they are year specific..
Aswell I've read I could just separate the cases and swap 4th and 5th gear..
Thanks!!!!
Old 01-30-2017, 10:03 PM
BrakeExpert's Avatar
Default Re: 87 HF Trans Swap Into 88 Sedan Questions
I'm no expert on the EF chassis, but if I recall, the 84-87 Civics are pre-D series, meaning I don't think the 88 Civic engine will bolt up to it. Also, I would assume the axles may be different, the 3rd gen (84-87) had a macphearson strut suspension and a different wheelbase/track so I can only suggest that there may be several other differences. Or were you wanting to swap the engine and trans from the 87 HF into an 88?
Old 01-30-2017, 10:11 PM
Was thinking the same thing, I've been trying to source a HF trans, but now instead I am trying to find a HF 2.95 fd vs. My factory si 3.88 fd.. if I'm correct that should lower my rpms thus for greater mpg.. correct?
scottiefenton90
01-29-2017 04:34 PM
andrey320
15
01-20-2008 09:35 AM
madhatter07
08-30-2005 11:35 PM
Serdar
11
02-21-2004 11:54 AM
ScottEK
08-07-2002 02:01 PM
Quick Reply: 87 HF Trans Swap Into 88 Sedan Questions
